Results 1 to 15 of 15
Steel brake lines on 07 CBR600rr?
    Anyone have an 07 or later CBR600 and install dual steel lines?
    I ordered them up, including a bleeder bolt for the master cylinder... but upon closer inspection I'm not sure if it will fit?
    The 07 and later CBR's have the upper banjo bolt going straight down... and I'm afraid a longer bolt won't clear the fairings, etc.
    Anyone do it?
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Westford, MA
    Re: Steel brake lines on 07 CBR600rr?
    There's a company called HEL that will custom build'em for virtually any bike.
    http://helperformance.com/
    ...I have your pants!!!
    Banned G21forme's Avatar
    Lakes
    Quote Originally Posted by Rossco View Post
    I don't think the issue is the lines it's how they are routed, ss lines don't follow oem contours and the banjo bolt being the issue. 35 the banjo bolt goes down? Doesn't a double banjo only add 3/8 of of an inch? pm chuck he might have ss lines on his blade.
    Yep... the stock banjo goes straight down... never seen one like that before.
    The stock setup only has a single line... and they put a 90 degree bend in it. (So it comes up from the brakes vertically then turns horizontal under the master cylinder.)
    I'm worried there won't be space for two lines to come up and turn 90 degrees... plus the extra bleed nipple.
    Tony
    #331 CBR929RE's Avatar
    Bridgewater, MA
    I don't know about stock stuff as mine has only had race fairings on it since I bought it and came with the SS lines and Woodcraft clip ons. I'm not sure the banjo bolt is gonna fit, if it does I'd bet it would be real tight. but with the bolt going up through the bottom of the master a bubble getting caught there isn't as much of an issue as it is on a radially mounted master.
    if you're worried about it just get a Brembo that has a built in bleeder on top of the master
    good point that the bubble is less likely to trap at the top with this setup...
    Tony
    Quote Originally Posted by 35racer
    You have a radial master. Shouldn't need a bleed nipple on the banjo bolt as there isnonenonntop of the master cylinder. No need for one on the banjo at the master.
    hmmm.... this is news to me, Degs.
    I am not at the bike, but are you saying there is an actual bleed nipple somewhere that I am missed ... or the nature of this type of master cylinder is that it bleeds off air?
    Tony
    beige camry attack mojobreakfast's Avatar
    Salem, MA
    I put Speigler SS lines on my 08 CBR600RR before I sold it. It was one down from the master cylinder to the caliper (left or right, your choice I think) and then a double banjo at the caliper and a shorty "up and over" line to the other caliper. I know this isn't a true dual line setup but it worked really well.
    no bikes currently
    Quote Originally Posted by mojobreakfast View Post
    Yeah...that is similar to stock... which would probably work just fine too but I already ordered the dual line setup.
    Tony
    Nov 2008
    Framingham, MA
    I also got a double banjos on the hel lines on my 07 600rr. Fairing clearance is fine with my race bodywork.
    Yes, the 07 and up came with the radial master. It has a bleed nipple on top. It's next to the remote reservoir hose. A bleeder on the banjo is redundant.
    You da man, Degs! Just got a chance to check out the bike and sure enough there is a bleed nipple near the master. It's not attached to the bolt that holds the line in, which is the only place I had ever seen them before.
    Cool...thanks all!
    Tony
    Member dudutzu's Avatar
    Quote Originally Posted by 35racer View Post
    Cool...thanks all!
    So how did you end up Tony? did everything go smooth with the installation?
    Quote Originally Posted by dudutzu View Post
    Yep...installation went smooth and no issues.
    thanks !!!!!
    Tony
  1. FS: Steel Braided Brake Lines Goodridge $40
    By Crash Dummy Denno in forum For Sale
    Last Post: 01-04-10, 07:32 PM
  2. Looking for steel braided brake lines
    Last Post: 11-17-06, 02:57 PM
  3. Installed Stainless Steel Lines couple ?'s
    By Lucky13 in forum General Bike Related
    Last Post: 08-28-05, 05:57 PM
  4. Stainless Steel Brake Line
    By craig in forum Bike Maintenance
    Last Post: 08-28-04, 12:01 PM
  5. Repair steel-braided lines?
    By zx-stewie in forum Bike Maintenance
    Last Post: 04-14-02, 06:33 PM
