Results 1 to 9 of 9
How To : Steering Stem Droid Mount/ Ball Mount for GPS
    Member importcustomx's Avatar
    Feb 2009
    Topsfield
    Hey guys,
    So after seeing all the different style mounts out there, i got tired to looking and not seeing what i wanted. I wanted something that was smaller, looked oem, not huge and obnoxious.
    I made my own.
    The tools youll need:
    A MIG Welder
    Angle Grinder
    Drill w/metal bits
    small hack saw
    items used
    I used a Motorola DROID RAZR Car dock i had for the ball
    small bolt
    .5in Bolt 4 inch length
    i took the .5in bolt and cut the threaded part off...so i had the nice smooth part of the bolt. I ground down the end with my bench grinder and got it smooth and tapered.
    Then i notched in the slots so i could put orings in there, so i could get my nice snug fit. little trial and error, but after 5 minutes i got it work.
    After i got that situated, i used a center punch and marked the center most part on the head of the bolt...then i clamped it into a vise, and drilled a hole straight down into the bolt. same size drill bit as the small bolt.
    Now after i did this, i took the Droid Car dock i had (For me razr) I used a hacksaw and cut the ball off, then grinded that area so it was smooth again.
    Found the center point on the ball and center punch, and drilled it out... was very careful drilling the ball out...dont want it to get hot and melt, and dont want to drill through it.use the same size drill bit as the same size small bolt your using.
    I Actually Drill and Tapped the ball so it threaded onto the small bolt.later on when i attached it to the small bolt, i use adhesive too.
    Inserted the small bolt into the hole and make sure its good.
    Now insert the small bolt into the hole you drilled onto the head of the big .5in bolt. make sure its the height you want etc.
    Once its good, tack weld it, and finish it up. then grind it smooth if you want to make it look nice.
    Then take the ball, fill the hole with a little epoxy and screw the ball onto small bolt.
    now your done!
    i have ridden over 1500 miles with this, not one issue.
    The cell phone is held in by the car dock. the car dock has a piece that actually charges the phone so the charging piece that goes into the phone helps secure it into the case. works great for me.
    Here are a few pictures of what I've made.
    this is on my 2012 Honda CBR 600RR
    1985 Honda Goldwing Aspencade ::::Current:::::
    1984 Honda Interceptor VF500F ::: Project::::
    2012 Honda CBR600RR :::::Current::::
    2004 Honda CBR600f4i :::Sold:::
    2005 Honda CBR600f4i :::Sold:::
    Lifer 01xj's Avatar
    CT
    Re: How To : Steering Stem Droid Mount/ Ball Mount for GPS
    Very impressive. What GPS program are you using?
    Apr 2008
    Boston, MA
    What do you do if it rains?
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    I can machine custom stuff like that faster and easier, should you ever want to try me. Here's the one I made to fit my Zumo 550 to my Triumph Tiger 800, nestled between the gauges and the windscreen:
    Been thinking about making a mount for my iPhone or garmin... But would want something not obtrusive and easily removable.
    Looked around online and everything either seems overly expensive or not practical on an f4i.
    Maybe your idea of a homemade mount is the way to go....
    Good write up.
    Quote Originally Posted by Kazinator
    Good write up.
    You gotta check out white horse gear. They have everything. I need to get a mount for a phone or gps and wire in a charger.
    Apr 2002
    Central MA
    Twisted Throttle has one of the best selections of GPS mounts for all kinds of bikes. Give them a look too, or ping me for a custom made one. I work cheap.
    Feb 2009
    Topsfield
    Quote Originally Posted by GNTurbo6 View Post
    ride faster... same thing youd do with all the other steering stem mounts...take it off and go old school...memorize directions a piece at a time
    if people have car docks and want me to make them for you feel free to message me. toss me some money and ill make em happen
    Feb 2009
    Topsfield
    sprint i may get in touch with you about making these. id like one thats cleaner or machined.
    eventually sell em!
    google maps on my android phone
  1. For Sale - Other | Ball Mount with Ball - Class 3 - 2" Ball - 2.25" Drop $10
    By MFChop in forum For Sale
    Last Post: 08-31-15, 08:26 AM
  2. For Sale - Other | Ball Mount - Class 3 6" drop - $10
    Last Post: 05-14-15, 02:15 PM
  3. Replies: 3
    Last Post: 03-30-11, 02:43 PM
  4. GPR steering damper + mount
    By ridnwb in forum For Sale
    Last Post: 02-05-10, 05:30 PM
