does low street pressure cause premature tire wear, improper wear patterns, and worse handling?
last set of BT014's got me over 8k miles...but current set are around 6k. Pressure front/rear was 28/23..recommended is 33/36.
the front's left seems to be wearing more than the right, it doesn't fall into turns as easily, and it doesn't feel planted in the canyons while leaning (I'm in CA btw)
I was reading old threads, and most of it is track talk. The only info I could get, is (moving with temp changes) higher pressure on the street, and lower at the track since the tire heats up more, and lower pressure = more contact patch.
