Results 26 to 50 of 99
V-strom build
    Lifer Stromper's Avatar
    Eastern Ct
    Re: V-strom build
    I think the alternator is 1 wire with integral regulator but if your keeping the stator you should upgrade to the series R/R
    Randy are you going to the peep show camp out... I may
    The exhaust set up looks very good hope it works for you
    The calculus of hate
    Re: V-strom build
    So how does it sound?
    stopped at RMS yesterday, waiting for a side cover gasket from suzuki, before they took it apart, they installed a new battery todiagnose the charging system, so they have heard it, I'm told it's loud, but probably passes the 92db level at idle for inspection and that it does not sound like a 1000cc twin, more like a 1000cc thumper
    when I get it back, I will take a sound video and post
    Re: V-strom build
    a little louder than I had hoped, I somehow need to quiet it down 3db
    Re: V-strom build
    Re: V-strom build
    That actually sounds really good! Little poppy, but good!
    If you want it quieter, maybe get a large washer with a 1" ID, weld a little piece of 1" tubing to it, and then weld it inside the exhaust tip as a small reducer. Shouldn't loose any power, and it'll give you back a little back-pressure as well as cut the DB's.
    I'm thinking it would look like this when done... only not as nice. Lol...
    Eastern Ct
    Re: V-strom build
    Coming home the sewing machine noise was ahead of the exhaust
    I was serious about the snuff or not
    Re: V-strom build
    I searchd for snuff or not on ebay, the one you picured is way more money than I want to spend, more than I paid for the exhaust and only 1¼-1½ size, my pipe is 1 3/4 I found a reasonable price snuff or not for 2¼-2½ size
    has given my idea, may the combination of a short downturned tailpipe, exhaust wrap and lower idle will get me the 3 db that I need to be legal
    Re: V-strom build
    I never have that much traffic on my street, all my neighbors came home from work at exactly the same time neighbor across street's kid was having a tantrum, tire noise from traffic is as loud as my exhaust , and crickets, locust and other wildlife in background is making quite a racket as well. I may redo the video in a little more quiet time to get better sampling of exhaust sound
    Re: V-strom build
    Quote Originally Posted by Danny500 View Post
    sounds a lot better in video than in reality, it is easily as loud as aftermarket Harley, my urologist has told me my penis is shrinking, but not that much
    Re: V-strom build
    just ordered a pair of these
    Re: V-strom build
    legal @ 91db
    Eastern Ct
    Re: V-strom build
    emgo ?
    Re: V-strom build
    getting ready for my next phase of my build
    trying to decide what way to go regarding auxiliary battery
    my current thoughts are
    a.
    multiple motocycle batteries in parallel take smallest space, do CCAs add up when you when you wire in parallel ?
    b.
    Type 51 Optima Yellow top, size for a Honda Fit, 450cca, narrow enuf, but kinda tall for the space
    c.
    other recomendations ? should I consider Lithium Ion ?
    my goal is to have as many CCAs as I need to start in -50°f
    Eastern Ct
    Re: V-strom build
    Assuming thick wiring and a healthy starter solenoid batteries in parallel will have amperage added so more cold cranking
    I think car batteries will work but am concerned about if they are drained they may use so much charging current it would strain the
    regular charging system
    You might look into some marine / camper battery switches allowing you to take some off line or add them when needed. In an old mechanical world you could add batteries in series 24V to spin your starter. If dead cold this will spin it faster but MUST be isolated from modern electronics.
    Lastly lithium Ion grenades perform WORST in cold temperatures requiring a warm up etc before cold cranking power is available,
    The other concern is at some low voltage I think below 9V the electronic control system goes to sleep so won't start
    Also recommend a small hole so a tube from a can of starting fluid can be inserted into the airbox when needed
    Re: V-strom build
    Remember Rich, that I am also installing a belt driven 60 amp one wire alternator, the auxiliary electrical system will be completely independent of the stock wiring with the exception of a trigger wire for a relay, I don't even think I will add a jump start switch, I will just carry a short set of custom made jumper cables
    Eastern Ct
    Re: V-strom build
    Fords did have an independent starter solenoid you could add to the starter system
    Or a battery switch and you could choose which system. I would think the 2 R/R might get confused with 2 generator sources
    Perhaps stock run electric clothing and accessories and 60 amp the bike
    Posting Freak
    Jan 2003
    Re: V-strom build
    Congrats....you have the ugliest freakin' exhaust I have ever seen! I hope you were going for that?
    Eastern Ct
    Re: V-strom build
    We strommers award function over form, I did recommend a look at emgo though
    Re: V-strom build
    Quote Originally Posted by Tricklidz View Post
    thanks, I'm going for another one ot these
    a rat bike award I got for my SV650
    Re: V-strom build
    Yes, I have been contemplating using a Ford starter relay as my primary power switch and possibly a second for a connection to the main bike wire harness in event of yet another oem charging system failure
  21. #46
    Re: V-strom build
    You've never met Randy?
  22. #47
    Ense petit placidam sandman's Avatar
    sema
    Re: V-strom build
    its not rated for continuous duty
    get a cole heresy continuous duty solenoid
    jim
    "Molon labe"
  23. #48
    Eastern Ct
    Re: V-strom build
    Yes sarter duty don't know if coil overheats
    regular auto relays can be found up to 40 amps
    Amazon.com: automotive relay
  24. #49
    Re: V-strom build
    Probably would of been cheaper to strap one of these on the back of the bike and just fire it up whenever the extra power is necessary.
    Honda EU1000i Model Info | Super Quiet 1000 Watt Inverter Generator | Honda Generators
    Really.
    Wire in a battery charger, DC converter, microwave, stage lighting, space heater, coolant/block heater etc.
    You think I'm kidding, but if you make a mount to attach it to one of your two racks in the back, then you'd be able to run it all winter and take it off in the summer. Plus you'll be able to move it to your next bike that you buy.
    2016 BMW S1000XR
    Re: V-strom build
    Probably would of been cheaper.
    hardly, and I am paying a local fabrication shop to machine parts and my dealer to install them, I expect total outlay to be about half the cost of that inverter
  1. New V Strom XT or ???
    By TheJRM in forum General Bike Related
    Last Post: 09-05-15, 09:06 PM
  2. For Sale - Motorcycles | 2012 V-Strom 650 ABS
    By No Quarter in forum For Sale
    Last Post: 08-30-14, 09:07 PM
  3. '06 Suzuki V-strom 650
    By Intrepidse17 in forum For Sale
    Last Post: 10-25-13, 06:16 AM
  4. My V-strom has cancer
    Last Post: 05-08-12, 07:48 PM
  5. V-Strom Yaweh provides
    Last Post: 10-22-04, 02:08 PM
