Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
V-strom build
    V-strom build
    Finally got started on something I have been putting off too long
    first will be my 2 into 1 exhaust, then the external charging system
    it's lifted in the air with my EazyRizer
    Re: V-strom build
    Re: V-strom build
    Are you going to wash it first?
    Re: V-strom build
    my 2 into 1 pipe
    Re: V-strom build
    nah! I will clean the parts I take off before I put them back on
    Re: V-strom build
    Wow!!
    What are you going to be running with 600w??
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2005 Kawasaki Ninja 500R **
    instagram @veshlife
    Re: V-strom build
    Wow!!
    a toaster oven
    seriously, 400 watts stock is lacking in an adventure bike, most adventure bikes crank out 550-800 watts, it takes 250watts just to keep the stock lighting, fuel pump and instruments going , the remaining 150 is gone before yo know it, incomplete heated gear riding solo will use that
    unlike Terry (RealShelby) I plan to retain the stock system, I will have 1000 watts available once I get it installed, I would like to have electricity available for complete rider and pillion heated gear and auxiliary lighting with some to spare. Reason for single sided exhaust is to make room for auxiliary battery box
    Re: V-strom build
    And of course the toaster oven!
    Re: V-strom build
    for now, I am at a standstill with my limited collection of tools, I need to buy some 6 point deep sockets to continue with disassemble
    Re: V-strom build
    Douche that pig in pb blaster while you're waiting.
    Re: V-strom build
    yep, already done that twice... exhaust clamps, I can get at all of em except 1 with a box end, the clamp on the rear cylinder head pipe outlet will require a deep socket, + u joint and extension that I do have
    I have been thinking I should order some Kroil, I have heard it works better than PB Blaster
    Hanover, NH
    Re: V-strom build
    PB Blaster? You mean oxy/acetylene?
    Lifer Stromper's Avatar
    Eastern Ct
    Re: V-strom build
    Sometimes just cut them off
    The calculus of hate
    Re: V-strom build
    I was able to get at the rear headpipe clamp once I got the right side muffler out of the way with a box end
    but now,
    my EazyRizer is malfunctioning, not sure what I did, I can't get it to go down. I have my exhaust disconnected and loose, just can't fish it out with the mount setup I used, it was easier to get at the bolts and works better for working on the alternator, but I have to lower it down to take one side of the footpeg mount (EazyRizer footpeg mount, not bike)to fish the exhaust H pipe out and put the Y pipe in. Luckily, its situated right under a beam that I can support the weight by hanging it while I get the footpeg mount out of the way, but eventually when the project is done, I will have to lower the bike when I finish the project
    Re: V-strom build
    work is slow with other priorities
    ordered a muffler yesterday from Amazon, with my $40 coupon, I paid $19.95 for a Thrush Cherry Bomb and a couple of chrome hangers
    Eastern Ct
    Re: V-strom build
    40 years ago I had a pair of those on my Buick Grandsport
    Re: V-strom build
    it will be a 32 lb weight loss
    Re: V-strom build
    I dropped my bike off at my local fabricator today, to fabricate a mid pipe, put the stock muffler back on so that I didn't have to ride there with a straight pipe
    get in my GFs car as she followed me another customer parked beside us backed out and right into my bike, crunch, broke front left turn signal, clutch lever, hand guard and bar end, fucking asshole with no insurance
    Eastern Ct
    Re: V-strom build
    Oops o well don't get an ulcer over it
    Re: V-strom build
    On a good note, the short 6 mile ride to the shop riding with 2 into 1 exhaust, was noticeable smoother and zippier performance in the <4000 rpm range where VStrom 1000s often stumble
    Re: V-strom build
    progress
    V-strom build-11214141_10204129028979990_7113830986036324169_n-jpg
    Attached Images Attached Images V-strom build-paxp-deije-gif
    Re: V-strom build
    So how does it sound?
    Re: V-strom build
    don't know yet, battery is dead, charging system is shot, sitting at B&B Fabricating waiting for RMS to come pick it up
    Dublin, NH
    Re: V-strom build
    a toaster oven
    Thought about changing out the headlights for an LED setup? I dunno if they have replacement LED projectors, but they take a hell of a lot less juice than halogens do.
    2015 KTM 1290 Super Adventure
    Re: V-strom build
    the primary purpose of the auxiliary charging system is extra juice for heated gear for 2up sub freezing rides
    going to LED headlamp would gain about 75watts, only a small dent in the needs to meet my goal, I would still need the auxiliary charging system
