Hello Folks,
I recently purchased a Street Triple R and am in the process of tuning it up for my self. I had it tuned professionally last week but had some questions around the correct sag for Street riding
Currently my settings are as follows
Front
Rebound : Soft
Compression : Soft
Total travel : 120 mm
Sag : 22 mm
Rear
Rebound : Almost Soft (a few clicks away from Soft)
Compression : Between Standard & Sport
Total travel : 126 mm
Sag : 37 mm
I remember reading that the sag should be between 28% to 33% of the total travel so that puts the front between the range of
33.6 mm to 39.6 mm which would mean that I am wayyyyyyyy offf.
The rear seems to be in range.
The bike was previously a bit stiff in the front and now feels great going over bumps.
I think my rear set up is good but the front still feels a bit iffy at times and feels like its diving under semi-hard braking.
Should I adjust the front sag or adjust the Rebound/Compression and go Standard.
I will tool around with the settings but wanted to get some pointers from our initiated lot.
I knew I should have stuck around longer when they talked about Suspensions at the end of the Lee Parks Clinic.
