Results 1 to 13 of 13
tire opinions
    tire opinions
    the KTM needs some new sneakers. when i bought the bike it had a fairly new Avon Distanzia on the rear and an almost spent battleaxe on the front. well now the front is done and so is the rear. ive put 3.5k miles on it already. my original plan was to match the rear with a front Distanzia but since the rear wore out so fast now im thinking...not so much. come to find out, the Distanzia only comes in a 160 in supermoto compound, which is pretty soft. ive checked out similar style tires from the usual suspects (dunlop,metzler,michelin,conti,pirelli,bridgestone) but no one seems to make that style tire in a 120/160 combo (well, except Avon but im changing a tire every 4k miles)
    im enjoying my dirt road adventures lately and will most likely continue to do so. im leaning towards the Michelin Pilot Road 3 Trail ( http://www.michelinmotorcycle.com/in...ilotroad3trial ) anyone tried these or maybe have a suggestions/opinions on something ive overlooked?
    Re: tire opinions
    I just mounted Pilot Road 3's up on my V-Strom. Looks like the big difference between the regular PR3's and the Trails is the distribution of the split compound. Tread cut looks the same. My experience might translate.
    I am no tire expert, so I have a hard time giving you detailed pros/cons. But so far I like them.
    That said I have a very hard street/tour bias and do hard commuting miles on my bike. Lately I too have been enjoying those dirt roads, but that terrain is 2nd priority for me.
    PR3's are good on pavement, with one caveat that I'll get into in a moment. They are okay on well graded dirt. And serviceable on looser stuff. They are not so hot in mud, which I found out the hard way last weekend. They spin very easily while they don't clump much and seem to clean okay, they do not grip much in the mud either.
    I came from the factory Bridgestone Battle Wings, which I wore the crap out of. But I think the Battle Wings were better off pavement. At least marginally.
    Basically they kinda do what you would probably expect by looking at the tread pattern; roads first, everything else second.
    The one gotcha with the PR3's is the handling is just a bit off. I feel like they fall into corners a bit faster and require more effort at the bars to stand upright on exit. I am hoping I just get used to it, but I do feel the Bridgestones were easier to ride. A couple times it has caught me off guard and I have wound up way off my line.
    If these PR3's go for 15k miles or something like some suggest, my cheap ass will overlook some handling oddness.
    Re: tire opinions
    thanks for the input bubba. like i said, ideally i would like a similar tread type as the distanzias (90%on-10%off) im willing to possibly do a 150 on the rear but getting a matching front is tough. pirelli scorpion trail comes in a 120/160 combo but i dont know anything about them, like how well they wear. and Conti has the TrailAttack in a 120/150 combo, but again. no idea on performance or wear
    Re: tire opinions
    I did not know the distanzias were a 90/10 tire. Like I said, I'm no tire expert; I don't know most of the options. 90/10 is about what I would call the PR3's. I bet they are comparable.
    Pilot Roads are supposed to wear like iron. I'd be really disappointed if I don't see at least 10k out of these things.
    I thought I read somewhere that the trails were intended for heavier bikes like the BMW 1200GS.
    I93/495
    Re: tire opinions
    This is a problem why? I love it when you can just fall into a corner instead of horse the bike over
    So putting trails on a lighter bike should make them last even longer
    I was getting 8k out of PR2's on the 650. I bet you can get 10k out of them easy as long as the center doesn't wear out too fast, which is where the trails would really help you out more on your commute.
    2012 Tiger 800 XC
    Re: tire opinions
    I am having a hard time putting the handling thing into words. It is unsettling. Hoping it is just what I am accustomed to and I learn to live with it. But in the meantime the bike doesn't always do what I expect it to, a bad thing in my book.
    Either way the delta is worth mentioning.
    My point with the intended application is that maybe finding sizes for a KTM 690 is a problem for the trails, but not for the regular PR3's. Looks like the Trails only come in one size right now.
    Re: tire opinions
    Run the 150 distanzia in the regular compound.
    No 120 for the distanzias
    Re: tire opinions
    ? 17"
    I ran the distanzia's 120/70-17F and 160/60-17R on my sV, I thought they sucked actually, good as a fairly sticky sport tire on pavement, didn't last any longer than Pirelli MTR60-Corsas, that are awesome in wet and a lot better on gravel than the distanzias
    imho, the distanzia's weren't any better on gravel than Azaro STs and only lasted as you say 4ką compared to 12k for Azaro STs (now Storm's I believe)
    tried Conti Trail Attacks once, ok, but again, no better on gravel than Azaro STs and lasted nowhere near as long, maybe 7k iirc
    Mar 2004
    Lynn, MA
    Re: tire opinions
    Bubba, et al...The Michelins fall into the corner because of the v shape to it. The Bridgestones have more of a u shape. Its prevalent in almost all the Michelin tires. For sportbikes and those that wanna corner hard, this is a good thing.
    Re: tire opinions
    This is what I've heard. I believe this may be my first time experiencing it first hand. It is ... different. I actually think I prefer the U.. I am used to it.
    Member rpiian's Avatar
    Georgia, VT
    Re: tire opinions
    Indeed. I have almost 6k miles on a 180 Pilot Road 2 rear with roughly 5/32in of tread left. (SV1000)
    I'm quite impressed as it has worn evenly and performed well. I only had a few pucker moments where the rear stepped out and that was when the tire was new. Maybe it had some mold release. I dunno.
    My previous rear tire was a Pilot Power, which became squared off from all the commuting I did during that time (4k miles), prompting me to buy the Road 2. Before that, a severely worn Michelin HPX from when I got the bike(<1k miles).
    Now I don't have a dirty bike, but I do spin the tire on local dirt roads and the Road 2 keeps me in a straight line. It's also a fantastic wet weather tire. Huge tread depths keep the water pumpin'!
    Oddly I run a Pilot Power 2CT up front and I find it to be a good combo.
    Lastly I would say I'm a semi-aggressive motorcyclist and I ride at the pace so I'm less apt to hurt myself. My choice of Michelin tires have suited me well. My 2 cents I guess.
    -Ian
    '81 KZ650 CSR
    '06 SV1000S
    Quote Originally Posted by RandyO
    ? 17"
    That makes sense since the distanzias in a 120/160 combo only come in supermoto compound. That's why I said no 120 avail, I don't want to burn through them.
  1. For Sale - Services | $10/tire change + dynamic balance - June 2021 tire changing blowout special (hah)
    By PurplePackage in forum For Sale
    Last Post: 06-24-21, 03:00 PM
  2. For Sale - Parts & Tools | Harbor Freight tire changer with motorcycle tire attachment
    By -Dutch- in forum For Sale
    Last Post: 06-21-15, 11:31 AM
  3. Tire Opinions
    By KawiSmurf in forum General Bike Related
    Last Post: 06-18-09, 06:35 PM
  4. Tire repair opinions
    By Ericthejet in forum Bike Maintenance
    Last Post: 06-23-08, 06:29 PM
  5. Rain Tire necessity/opinions wanted
    By trackdog in forum Pit Area
    Last Post: 01-11-05, 09:31 AM
