Results 1 to 5 of 5
Tire pressures during winter months?
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    I was wondering if anyone has tried running lower tire pressures during the winter months to get their tires up to operating temp quicker? If so how much lower did you drop the PSI?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Tire pressures during winter months?
    About 10‰ under manufacturer recommend pressure for me, but I'm on a pretty non-traditional bike.
    Lifer golden chicken's Avatar
    Attleboro, MA
    In spring/fall I typically set my pressures "cold" around 2-3pm, or the warmest part of the day. In summer, I set them "cold" in the morning. I use the same pressures all year.
    Quote Originally Posted by duganc1717 View Post
    I drop 2 psi when ground is cold enuf snow sticks instead of melts, if I happen to go on a ride on an exceptionally cold day, I may drop the pressure more, just for the day, for instance on a -12f ride, I would drop the pressure another 5 psi
    more for the ride rather than the illusion of improved traction, cold motorcycle tires have the resilience of a hockey puck
    remember tires only provide half the surface friction, the road surface provides the other half, cold pavement is no stickier than cold rubber and they don't put heaters in many roads around here (I understand they do in Iceland)
    Dec 2011
    Marlboro
    I use more or less the same pressure in the winter, but my "cold" tire temperature is a 45-50F garage.
    Once you get outside and it's 20F-30F, I suppose that's a couple of pounds less.
    Through laziness, I've ridden a couple pounds less than that and I didn't notice any difference.
    Then again, my winter riding style usually means staying away from situations where you would notice a difference .
  1. Tire Pressures @ the track
    By Jim in forum General Track Day Talk
    Last Post: 07-28-14, 05:52 PM
  2. Street Tire Pressures
    By Doc in forum Bike Maintenance
    Last Post: 05-12-11, 03:55 PM
  3. ex500 tire pressures
    By catch2otwo in forum Bike Maintenance
    Last Post: 03-04-09, 10:42 PM
  4. Tire pressures, etc
    By TheIglu in forum Dirty Bastards
    Last Post: 10-27-06, 04:06 PM
