Results 1 to 8 of 8
more tire question
    I Dance With Will
    Oct 2002
    unknown
    more tire question
    if a Michelin tire has been sitting around for 2 yrs. is it still good?
    "fuckit!"
    Lifer Karaya One's Avatar
    Springfield, Mass
    more tire question
    Check out my eBay store!
    Dave - Motorace - Michelin
    Springfield, Mass
    more tire question
    All tires have a production code, a "born-on-date".
    Lot next to the DOT label on the sidewall. You should see 4 numbers in a block.
    For example - 2804.
    This means that the tire was produced the 28th week of 2004.
    You will never, ever find an expiration date on a tire. As long as they are stored properly they will be fine. Keep them out of the sun, cool and dry and try to prevent them from freezing.
    A frozen tire will crack if shocked.
    Tires don't, and cannot "dry rot". There is no moisture inside to cause them to dry out. The rubber degrading is what causes the cracks.
    The exception would be race tires run through heat cycles and stored. The nature of these are such that they may be more prone to "age".
    Aug 2004
    NH
    more tire question
    Manufacturers state that any tire stored in a controlled environment has a shelf life of 5 yrs. If it's older than that, don't take the chance of using it.
    I Dance With Will
    Oct 2002
    unknown
    more tire question
    well it's just over 2 yrs and it's not stored in control env. and it was mounted on another bike.
    "fuckit!"
    Lifer ZX-12R's Avatar
    Candia, NH
    more tire question
    I wouldn't use it if I were you. Your 10R has enough power to make a bad tire look even worse in terms of grip. Don't chance it! Buy a new one off the internet!
    I Dance With Will
    Oct 2002
    unknown
    more tire question
    well ok. where's the link? nevermind. let me find it.
    "fuckit!"
    I Dance With Will
    Oct 2002
    unknown
    more tire question
    actually anyone got a race take off? not sure if that's good idea either.
    "fuckit!"
  1. Tire question..
    Last Post: 10-11-06, 01:19 PM
  2. ok, another tire question...
    By chr|s sedition in forum General Bike Related
    Last Post: 06-27-05, 02:40 PM
  3. Tire question
    By Lucky13 in forum General Bike Related
    Last Post: 01-12-05, 07:36 AM
  4. Tire Question?!
    By oreo_n2 in forum General Bike Related
    Last Post: 04-09-02, 06:00 PM
