Results 1 to 10 of 10
tire wear
    Member xbootlickx's Avatar
    N.Worcester county
    tire wear
    I am currently getting 4.5k-5k mi with Diablo corsa III's .. is that about average ??
    im running 30/30 psi and have only ran them hard on the track ..
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    Re: tire wear
    you are way low...
    they should be 34 front / 36 rear HOT off the track.
    I got 9K mi out of my first set w/ 4 trackdays
    my current set has 6K mi and 2 trackdays, and my rear still looks new.
    Q
    Banned G21forme's Avatar
    Lakes
    Re: tire wear
    30/30 is way too low, I ran mine 34/36 iirc but I'm on different tires as the bike I bought had new tires. I thought running tires at lower psi generated more heat and so they wear faster but I'd ask the BostonMoto guys.
    Re: tire wear
    1 - what kinda bike? (EDIT: nevermind, saw the 1125R in your profile)
    2 - what are you running for STREET pressures? 30/30 cold is about right for the track, but way too low for the street...
    4.5-5k miles sounds about right considering how low your pressure are.... Like Q said, that's way low for street riding. Bring them up to ~35/35 cold and they'll go up a couple more lbs once they warm up a little.
    You'll have a little less traction available to you, but you're not using all of it on the street anyways and you'll get more miles out of them.
    Homeless, MA
    Re: tire wear
    measure hot, adjust hot, be happy
    /end
    Q
    Re: tire wear
    Tires don't get hot when they're gettin used on the street But I agree... measure after you've ridden around a little.
    N.Worcester county
    Re: tire wear
    will do .. ill try it out with this new set.. ty
    Posting Freak boloson's Avatar
    Oct 2007
    Re: tire wear
    30 front & 26 rear cold. direct from bomo regarding DCIII's
    Re: tire wear
    I have mine 30-30 hot. Worked like a dream on the 600rr.
    Bootlick, I think one statement in your original post was worded in a way that could be taken two different ways & cause some confusion.... You're saying the only time you rode them hard was when you were on the track... And you're not saying they're track only tires that get riddien hard, right? You're asking about street pressures?
  1. Tire wear, defect, or just cosmetic
    By backinthesaddle in forum Bike Maintenance
    Last Post: 11-17-13, 08:28 PM
  2. tire wear
    By SVRACER01 in forum General Bike Related
    Last Post: 09-20-12, 09:01 PM
  3. Darkside tire Wear
    Last Post: 10-03-11, 07:59 PM
  4. Tire wear question for the MW people
    By lrrs313 in forum Pit Area
    Last Post: 10-29-10, 08:38 PM
  5. Motorcycle Tire Wear
    By NHBusa in forum General Bike Related
    Last Post: 10-13-04, 10:58 PM
