Results 1 to 25 of 25
Valve adjustment?
    GRRRRRRRRRRRRRR! capt1014's Avatar
    Apr 2006
    Ashburnham, MA
    Valve adjustment?
    Does it need to be done on a fuel injected bike?
    http://www.facebook.com/#/profile.ph...&id=1185417660
    Live life now!....it has an expiration date!
    Friendship is like peeing in your pants,
    Everyone can see it,
    But only you can feel the true warmth.
    Jun 2005
    Re: Valve adjustment?
    yep...
    fuel delivery has nothing to do with it... it's got valves (unless it's a 2-smoke).
    Apr 2006
    Ashburnham, MA
    Is there a specific time when it should be done? i.e. mileage?
    Meriden, Ct
    Quote Originally Posted by capt1014 View Post
    R.T.F.M.
    Jun 2005
    depends on your bike and the adjustment method. I adjust the valves on the KTM all the time... Street bikes with "shim and bucket" need much less attention... 15K? I had 3x that on a KLR with no need for adjustment.
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    depends on bike / manf. for a 929 it is stated in the manual, but it is in the 10,000 to 20,000 range I believe.
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    Lifer BostonSVkid's Avatar
    Dec 2005
    Every bike is different. For example an SV get CHECKED first at 15k miles where as a Duc Monster S2R 800 is at 6 I believe.
    Just because you check them at those intervals doesnt mean they will need to be adjusted its just good to check them because over time they get tight and if they get too tight you will begin to damage the valves.
    Valve Clearances are also known as tappet clearances.
    2006 Ducati Monster S2R800
    Apr 2006
    Ashburnham, MA
    Ok well I bought it from a dealership when it had 4k on it, I am going to assume that it might be time for them to be adjusted, bike has 16.5k on it now.
    Jun 2005
    I'd check them, but I wouldn't be surprised to find them all within spec. Just make sure the motor is COLD when you check.
    Dec 2005
    What does your manual say???
    Apr 2006
    Ashburnham, MA
    If the valves needed adjusting would there be some type of performance issue or lack of responsiveness in the trottle?
    Apr 2006
    Ashburnham, MA
    Haven't looked.
    Reason I ask is because I'm trying to sell it and 2 people have asked about the valve adjustment.
    I'm going to assume that they were checked prior to me buying it rom the dealership and they were fine.
    Manchester, NH
    I would not assume that. Its a pretty time consuming job, not like just washing it to make it look pretty.
    Manchester, NH
    R.T.F.M.
    Alright, so I got Read The Manual, whats the F?
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    There could be a loss of performance, and when they're bad it can sound.....bad.
    Haven't looked.
    I highly doubt anyone would have checked the valves on a Honda at less than 12k mi.
    Everybody to the limit!
    Winchester, MA
    If they get too tight you can end up with a burnt valve seat, or catastrophic engine failure due to the valve hittting the piston.
    Valves tend to tighten up in their early lives so it's best to adjust them towards the loose end of spec.
    Meriden, Ct
    Haven't looked.
    The dealer did NOT check the valves at 4000 miles. Most modern I-4s call for a valve check at 12-15k miles or so. There was not reason for anyone to check them at 4000 miles. Don't be surprised if they are well within spec at the current 16.5k...
    Quote Originally Posted by RacerXnh10 View Post
    read the FUCKING manual!
    I had the valves on my 900RR checked at just over 20K by Mr. Kates and they were all fine. 2 cylinders were dead on, one was on the higher side of spec and the other on the lower side of spec.
    If you're a member of RRZone.com, they have downloadable manuals and microfiche for your bike in the downloads section. (same for 96-03 FireBlades [900RR, 929RR, and 954RR])
    Apr 2006
    Ashburnham, MA
    Thanks Chuck, I have the manual. I'm not too worried about it.
    I Dance With Will
    Oct 2002
    unknown
    when did you last change the plugs? that could be performance isssue.
    "fuckit!"
    Apr 2006
    Ashburnham, MA
    I have no performance issue was just curious.
    Meriden, Ct
    Well, that's a brilliant diagnosis for a problem that doesn't exist...
    Quote Originally Posted by trickphoto View Post
    yep...
    or hydraulic lifters like a harley
    Jun 2005
    Or a Wankel
    I Dance With Will
    Oct 2002
    unknown
    i didn't say it was brilliant. he mention performance issue. i didn't know. i do know that when i last change my plugs, it feels like a new bike.
    "fuckit!"
  1. SV-650 valve adjustment
    By NPDCPA in forum Bike Maintenance
    Last Post: 06-22-16, 09:00 AM
  2. valve adjustment
    By j4eric in forum Bike Maintenance
    Last Post: 06-30-11, 02:25 PM
  3. Valve Adjustment
    By emayn15 in forum Bike Maintenance
    Last Post: 03-13-11, 05:22 PM
  4. valve adjustment?
    By crowspeed07 in forum Dirty Bastards
    Last Post: 04-15-10, 11:52 AM
  5. Valve Adjustment
    By csmutty in forum Bike Maintenance
    Last Post: 12-31-09, 11:32 AM
