Results 1 to 11 of 11
water heater died//small leak
    Apr 2004
    boston burbs....
    I"m going to have to replace it.
    anyone have a connect/ reccomnd some one for this job?
    It's electric and an older/smaller one so water pipes will have to be adjusted. Just may be a bit beyond my skill.
    I'm going to have to get this done in the next 2-3 days. as of right now = no hot water.
    just when i was going to get the suspension done on the motard...
    hmmmm......
    Lifer LuvDog's Avatar
    Ashland, MA
    where is it leaking from? are you sure its just not a bad pressure relief valve?
    2003 ZX7R
    1995 916
    Apr 2004
    boston burbs....
    positive.... its lekign from underneath somewher..... the pressure relief valves/pipe is dry dry dry... a soon as i shut off the water entering into the heater.. the leak finally slowed ( ofcourse the tank is now empty : )
    i'll do it mysef.. it isnt that hard.... i think?
    hmmmm......
    Not hard at all. Get some copper, couple elbows, MAPP gas/torch and a decent cutter.
    2016 BMW S1000XR
    Lifer ZX-12R's Avatar
    Candia, NH
    The hardest part about changing a water heater is moving the old one when there is 300lbs of sediment in the bottom because the previous home owner didn't have a water filter.
    Apr 2004
    boston burbs....
    yup i'm working on emptying it out righ tnow.
    Its doesn't look hard.
    besides what grown man wil turn down the chance to wield a butane torch?
    hmmmm......
    Lifer Punjistick's Avatar
    Norwell, MA
    also get some emery cloth (sandpaper will do in a pinch), solder, and flux.
    Why not post this under "general bike related" that will keep us on topic.
    So, what kind of bike is it you have that has a water heater leak?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    www.bostonmoto.com
    Forum Rules
    I'm Sorry, What? Jank's Avatar
    Apr 2002
    North Walpole, NH
    Sounds like a cracked block to me...
    Chris J.
    Apr 2004
    boston burbs....
    uhh... woops... wrong section....
    hmmmm......
  1. Water pump leak
    Last Post: 05-11-13, 08:02 PM
