Results 1 to 11 of 11
wheel repair
    wheel repair
    i know this has been discussed before....
    i hit a rock on my motard this summer that bent both wheels at the lip on the right side. ive got the wheels off and completely disassembled (to be painted). i called MCWheel and asked if they could be fixed but they said not only did they not know if they could fix them but that they had to be fully assembled ( ) and there is a distinct possibility that while trying to straighten the bends that they may stretch or bend spokes in the process or even oblong the spoke holes which means that after they fix the bend i will most likely have to buy all new spokes and/or possibly a new hoop, hub or both anyway.
    replacement hoops from KTM run $345 (front) and $452 (rear).
    i can get non dimpled Excel wheels for $278 (F) and $392 (R) which is a little better but still pretty pricey.
    im not sure what to do at this point.
    Re: wheel repair
    Torch, block of wood, and a bfh?
    Sounds like you haven't got much to loose.
    Ashford, CT
    Re: wheel repair
    I agree with nh, it doesn't take much heat on aluminum to make it easy to bend. I've bent back brake pedals and brake levers that way on an old CR and you'd never know the difference. Just ask my brother..., he never knew I bent them on his bike.
    Jeff
    Re: wheel repair
    Is it noticeable when you ride it?
    Re: wheel repair
    visually? yes. can i feel it? no.
    id really like to go tubeless on these wheels though and i need the bead to back where its supposed to be. besides the lip the rim has a bit of a flat spot in the same area too.
    i think im gonna ship them to Wills. i put them back together yesterday. just gotta find a box or 2 to ship them in.
    Re: wheel repair
    Ahh ok.
    Re: wheel repair
    well you can always talk to Will Babb at Will's Rim Repair and see what he says.
    i have his number if you want it
    Dublin, NH
    Re: wheel repair
    MCWheel needs the wheels to be fully assembled so that they can put them on a balancer once they've straightened them. It doesn't make much sense to straighten the wheel visually if balance is still off.
    2023 KTM 890 Adventure R
    Re: wheel repair
    already did. go back a couple of posts
    MCW doesnt like doing spoke wheels but they will. they are the ones that said that damage to the spokes or wheel could happen that i mentioned in the OP.
    Dec 2003
    Ma
    Re: wheel repair
    If the rims function leave them be. If you really want to go tubeless, don't even drop the $ on painting or trying to repair these. have them as a set of functional spares or sell them to recover cost and let someone else deal with the headaches if they want. It sounds to me like MCW gets a thumbs up for being totally honest with you on their capabilities and the possible outcome. You don't want them telling you everything will be fine, and then coming back to say, 'so sorry it didn't work out, you're fucked'. Besides, if you ask smutty, he'll tell you the marchinsinis are worth more and also the marchinsinis are worth more.
    Re: wheel repair
    i have no use for spares at this time. ill never be able to sell them for enough to recoup enough money to justify new wheels. if i really wanted to, i could just pay my $250 deductible and have my insurance cover it.
    while i appreciate MCW candor they just didnt sound confident. Woodys in CO specializes in wire wheels and said it could fixed easily, but they wanted $100+ per wheel (not including shipping) because they want to true them and have them perfect when they send them back which is pointless since im just gonna disassemble them for paint.
    i called wills, twice, both time i got the machine but left no message. 20 min later HE called ME. i told him what i was looking for and he said hes done a few with good results. only 1 that he couldnt fix and he said it was taco'd almost in half. @$50 per wheel, ill let him have a go at it.
    worst case scenario in all this is an insurance claim.
  1. Wanted - Parts & Tools | Sv1000 front wheel, ideally silver. Or a GSXR wheel that interchanges
    By juha_teuvonnen in forum Wanted
    Last Post: 05-20-18, 10:03 AM
  2. wheel repair
    By youngblood in forum Bike Maintenance
    Last Post: 07-10-09, 12:27 PM
