Results 1 to 12 of 12
Can I take off my wheels on this lift ?
    Posting Freak danny86's Avatar
    MA/NH
    With this lift, can I take off say the front wheel only and not run the risk of the weight change causing the bike to fall over ?
    It's only $100.00. Its for a dirtbike
    http://www.discountramps.com/steel-dirt-bike-lift.htm
    Lifer eboos's Avatar
    Re: Can I take off my wheels on this lift ?
    Don't lift it up that high, and secure the frame to the lift. Then you will be all set taking off both wheels.
    MA/NH
    Quote Originally Posted by eboos View Post
    wat if i just want to take off one wheel ?
    Uxbridge, MA
    It should be fine so long as the girl's don't let it go....
    Laws of Physics say it will become unstable at some point....It does look like there is some type of "Lock" to hold it, but not sure...
    It's using the pegs as tie down points, so you should be ok. I'd normally run a strap over the seat and under the lift plate but those peg hooks should do the same job.
    Quote Originally Posted by danny86 View Post
    Secure it to the lift, and you should be fine. What I've done is just throw a strap over the bike and hook it to either side of the lift.
    Uxbridge, MA
    If this locks then I may get one also. I was wrestling the bike's around the other day thinking of how to lift them for simple Maint. work....
    coo..
    I need a new toy...
    live to ride seth399's Avatar
    Feb 2007
    CA
    I only have issues with my dirtbike tipping when I get to taking off fork legs or swingarm. If I am doing that ,I put a tie down around the footpegs/under the stand to keep the frame/motor put.
    LRRS #399
    MX #505
    TWINS! xrocket21's Avatar
    Central Maine
    girl on the left is cute but has TERRIBLE posture
    with the exception of danny86 and xrocket, you guys are all homos
    I've sen this ad before and my useless 2 cents, is that and I would plow both of those chicks until July, and they can leave their heels on too
  1. Anyone using a lift like this?
    By whynot in forum Bike Maintenance
    Last Post: 11-11-19, 07:46 AM
  2. Replies: 12
    Last Post: 07-01-08, 12:36 PM
  3. 8 men lift car
    By tonyd in forum General Bike Related
    Last Post: 01-10-07, 04:58 PM
