Results 1 to 9 of 9
wr250f Input carb rebuild
    Apr 2004
    boston burbs....
    So I'm cleaning the carb of the 07 wr250f tonight.
    Bottom part of the carb where the plug screw resides.
    I remove that bottom part off and well next thing I know on my work bench is a little metal pipe.
    appears to have fallen out of the carb.
    Now looking at the Parts diagram doesnt seem like that pipe is supposed to come out.
    Anyone know for sure? assuming its a vent pipe of sorts
    wr250f Input carb rebuild-capture-jpg
    here is the diagram. part that fell out is the thin long cylinder on interior of carb running from 11o'clock to 5o'clock
    I can put it back in the hole but it just seems like its going to fall out again. worse comes to worse i'll JB weld to make sure is stays in place
    hmmmm......
    Re: wr250f Input carb rebuild
    I believe that's your overflow tube. If the carb bowl fills too high, it allows the excess to drain vs filling your engine.
    Important piece.
    I believe they are almost always pressed in.
    Is yours threaded?
    Apr 2004
    boston burbs....
    Important piece.
    so if i get rid of it i'l get more gas in the carb= more powah!
    hmmmm......
    Apr 2004
    boston burbs....
    Is yours threaded?
    No threads, end doesnt look jagged like it broke off. I'll "assume" it was pressed in and tap it in with a good delicate touch to make sure its seated well. i've checked various pics of carbs online cant see one without it being in / pressed in the carb.
    I wonder if thats why it wasnt starting because it fell out ? besides the fuel stabiled fuel that put a nice varnish on everthing else.. ? hmm either way it will be hammered in moving fwd.
    hmmmm......
    I would expect the carb to constantly piss fuel without that tube in place. Without it the drain is at the bottom of the bowl instead of near the top. The float valve would always be open trying to fill, float would never.. float.
    My fear trying to re-seat would be leaks. If its loose enough to fall out then it is loose enough to either leak or fall out again.
    Probably worth a shot though. WTF. It's just a dirt bike. Major downsides include being stranded on trail or dying in a ball of fire.
    Apr 2004
    boston burbs....
    you're right.. would piss like a sieve. I'll give it a shot. odd it fell out . I mean i've jumped / more like dumped/ crashed that bike plenty no issue. and it falls out as i'm removing a few screws.
    hmmmm......
    You could use bearing retainer to help lock it in. Yamaha doesn't list a PN for just the float bowl, looks like about $100 to order by itself new through an Keihin dealer.
    Apr 2004
    boston burbs....
    bearing retainer it is..... Thx.
    I'll tap it well looks like it needs some encouragment to stay seated
    hmmmm......
  1. For Sale - Motorcycles | 2005 WR250f
    By PinHead in forum For Sale
    Last Post: 09-27-18, 06:34 AM
  2. '02 Yamaha WR250f $1500
    By klp in forum For Sale
    Last Post: 06-24-13, 08:24 PM
  3. 2005 WR250F
    By jcbell1007 in forum For Sale
    Last Post: 07-01-12, 01:09 PM
  4. Carb cleaning/rebuild
    By Variablevalve in forum Bike Maintenance
    Last Post: 04-20-11, 10:36 AM
  5. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
