For those of you with either a duc or triumph that has a single sided swing arm I am trying to determine the difference (if any) between the "bolt" pattern that the rear wheel uses for the drive pins. I know both brands use a 4 pin drive but what I am trying to figure out is are those pins on a same diameter circle from brand to brand. In other words, issues of alignment ignored for the moment, will a duc wheel fit on a triumph and vice versa? If any of you have one or the other brand and are willing to measure your wheel/axle for the pin to pin distance (and please note if your are measuring to the inside/outside/middle of the pin) that would be very helpful. Thanks
