Results 26 to 50 of 90
Wrapping bodywork instead of painting...
    Re: Wrapping bodywork instead of painting...
    No issues with fuel spills on it?
    Windham NH
    2. Also attempting fiberglass repair on bike. Can find out how much an iffy vinyl wrap job can cover up a shitty fiberglass job.
    Have you seen the tail on my bike? It is evidence that you should either have an experienced person help or do sufficient internet research before attempting for the first time. I watched a few youtube videos and then winged it, and it came out, well, awful. I also had a few gaping holes the size of tennis balls that spanned a few contours and creases, that made it a lot harder.
    I've seen your tail. You are a few coats of bondo away from being good to go. Maybe another patch or two of fiberglass from the back to keep it solid.
    go faster cdovego's Avatar
    Weymouth
    I hope the vinyl deals with imperfections....I've got lots of those on the Armorbodies...lol@me
    Do I need to fill and sand?? Gah...I hope not. If so, I'm going rattlecan instead...
    No, no prep besides removing stickers needed.
    Central Mass Powersports #123
    Weymouth
    No issues to date, I've spilled fuel on it and no fading/stain/wear.
    Rocky Hill, CT
    None. I also clean all of the crud attached to my belly pan with acetone every race weekend. The stuff is pretty chemically resistant.
    I am sorry, but this is wrong. If there are imperfections under the vinyl, they will show through. If your plastics are not smooth, you will need to do filling/sanding if you would like the finished result to look decent.
    Haverhill, MA
    Guessing this was on previously not too badly blemished plastics. As stated before, if there are imperfections in the surface you are applying the vinyl to they will show through the vinyl once applied.
    Apparently Mike and I were typing the same thing at the same time.
    Weymouth
    I did not do any prep besides removing stickers and I'm very happy with the finish on my race bikes.
    Haverhill, MA
    Ok, pretty sure those that are thinking about doing this are getting what painfullyslow and I are saying.
    When you "just removed stickers" and applied a vinyl wrap to your bike, was the condition of the existing bodywork such that it did not have a significant amount of blemishes of a size that would bother you if they were visible once the wrap was applied? Or did your bodywork have blemishes that are visible through the vinyl that just don't bother you that they can be seen?
    Bottom line is that whatever blemishes that are in the bodywork the wrap is being applied over will be visible once the wrap is installed. Whether or not those blemishes being visible through the wrap bothers you or not is a subjective thing.
    Chris put his on over new bodywork, so no prep needed. I've done some pretty fugly glass work that I'm sure would need a lot of sanding to make it look right
    Weymouth
    1 bike was spray paint base and the other was new body work out of the box.
    Both look great, it's that simple.
    The entire human race knows that more preparation equals better finish.
    Windham NH
    Here is a picture of my bike wrappedAttachment 40816
    Wow, I looked pretty damn closely at your bike and didnt realize it wasn't paint. Pretty cool
    Lancaster, CA
    Covered well enough already, but to add another POV: my race bike is wrapped. I spent way more time than was necessary to wrap a race bike, wanting as few seams as possible...when in reality, you can't see the seams from 5 feet anyway.
    - heat gun and vinyl squeege (basically a thick credit card with felt on one edge)
    - patience
    - good vinyl (as 'Slow mentioned)
    - knifeless tape
    - whenever possible, don't cut your vinyl right at the edge. Wrap it around the backside of the panel. And/or, if applying in pieces from a giant sheet, always cut off more than you think you need. Once you start stretching and getting the vinyl to conform to contours, you'll be amazed at how quickly that "huge piece" is now "crap, I needed 2 more inches." That's what she said
    A metallic color hides seams awesomely. My tail is metallic black, and I have to be within 2 feet to see the seams.
    Bill Cool --- CRA EX #47 --- 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle
    i know people dip body work for designs. i can only assume it can be done in solid colors as well.
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Quote Originally Posted by Mustang View Post
    - patience
    - knifeless tape
    Would you add "edge sealer" to that list of required items? Especially if someone was planning on doing stripes, etc. on their bike?
    Amazon.com: 3M Edge Sealer 3950 1/2 Pint 8oz For Vinyl Graphics: Health & Personal Care
    LRRS 919
    Lancaster, CA
    For the ends (ex. pieces that wrap behind the bodywork),yes.
    xxaarraa
    Guest
    Speaking of wrapping....
    Sep 2013
    Nice. How hard was that to do?
    LRRS 919
    xxaarraa
    Guest
    About 3.5 hours for the tank (including putting on a fuel pump, tank pads, carbon tank extender and carbon crash guards). The Aprilia tank has all kinds of complicated surfaces and contours, so I'd say about 2-3 hours for a tank, in general. I did have a helper who worked the heat gun while I stretched/wrapped the vinyl.
    Mar 2004
    Lynn, MA
    Thats gonna look killer on the bike!!!
    And as an update....Ive decided to paint the racebike instead of wrapping. Ive got some fiberglassing and sanding to do, and Ive already purchased the paint. In the next week or 2 Im heading up to GingahNinja's place to paint it. (maybe Ill just drink beer while he does the work)
    Windham NH
    Let me guess... red?
    Branford CT
    Team colors.........and its a Ducati so yes
    May 2010
    Somersworth, NH
    Ha ha Dont thing for once that you are getting out of this easy pal.... im learning you how to bondo and glass while you are here and I hope you like sanding... lol
  24. #49
    Mar 2004
    Lynn, MA
    Wrapping bodywork instead of painting...-t2ec16n-w0fizb-tsb9bs-pytng-60_57-a
    It may or may not look exactly or slightly like this Pete....you'll see soon enough
    Is sanding easier with beer, Brian?
    xxaarraa
    Guest
    The timeless Ducati look! Love it. Want to see pics when this beer induced sanding and painting is done.
  1. Recommendations for bodywork shops/painting fairings
    By NH848 in forum General Bike Related
    Last Post: 05-07-15, 08:33 PM
  2. painting bodywork - what are my options
    By Marc R in forum General Track Day Talk
    Last Post: 02-01-13, 12:56 PM
  3. Business | Bodywork Painting Review
    By knarlydog in forum Business & Product Reviews
    Last Post: 07-25-10, 09:49 AM
  4. painting bodywork/tank
    By kermita in forum Bike Maintenance
    Last Post: 08-07-07, 04:27 PM
  5. Spray painting race bodywork Need advice
    Last Post: 04-14-05, 09:31 AM
