Results 1 to 25 of 26
Anyone have a chain riveter I can borrow?
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    My bike is under the knife right now, getting new front suspension and brakes, new front and rear sprockets, a new 520 chain, and new tires. The only thing I don't have to finish the project is a chain riveter (well, and tire mounting equipment, but I'll probably just take the wheels somewhere and have them do it).
    Anyone around the area have a tool I could borrow for a few days, or want to help me mount it up? (there's beer in it for you either way )
    Thanks in advance!
    D
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Feb 2008
    Las Vegas
    Re: Anyone have a chain riveter I can borrow?
    I don't have the tool you need, but sounds like an wicked project!
    What are you doing for suspension, brakes, and tires?
    Carpe Diem
    '10 Yamaha R6-Race-
    Central VT
    Quote Originally Posted by SVenpointsixtwo View Post
    Thanks in advance!
    D
    I may have one to lend you if the last guy that borrowed it returned it...... Barring that, I think that Roadside will rent you one overnight fairly cheaply if I recall correctly.... I'll check on mine this afternoon. Regards, Jake
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Jeffersonville, VT
    Thanks Jake, if you can't find yours I will ask at roadside tomorrow night!
    Quote Originally Posted by MotoFreak View Post
    She's getting a '05 GSXR 750 front end with 4-pot tokico calipers, '07 gsxr master, and HEL stainless lines. Tires are a set of bridgestone BT016, and putting on -1/+3 sprockets with a 520 chain. Custom paint on various bits: top and bottom triple, calipers, faux 'earls'-style fittings on the HEL lines, and sprocket carrier.
    How she sits right now:
    Needless to say, I won't be riding tomorrow...
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Feb 2008
    Las Vegas
    That is SICK D!
    Chiwawa444 did that front end conv. on his SV650...looks good so far, can't wait to see it when your done!
    Carpe Diem
    '10 Yamaha R6-Race-
    Jeffersonville, VT
    Yeah I've taken a look at Mike's new forks, they are from an '06-'07. His 650 is baddical! I used the '04-'05 so that I could reuse the SV wheel and rotors.
    I'm hoping to have this thing back on the road this week (got a few days off work), but it really hinges on getting the tires on and then finding a chain tool.
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Central VT
    My chain tool is still in Montreal, sorry.
    Jake
    2006 ZX-10R
    Jeffersonville, VT
    No worries, thanks anyway! If I can rent one from RSM then it should be no problem.
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Feb 2008
    Las Vegas
    Come down to RSM tonight (in the cage is ok, Ill be in mine) and grab the chain tool...Bike Night being down there and all.
    Carpe Diem
    '10 Yamaha R6-Race-
    Infected Slyder's Avatar
    Concord, NH
    I wish you luck with the OEM gixxer radial master. Quite honestly I think it, along with that bogus BS crap stock OEM wannabe poser electronic damper, belong no where other than the trash can. Outta the crate you can squeeze the lever to the bar. Add stainless lines and bleed 2 bottles of oil through it, squeeze the lever to the bar.
    Hopefully yours pans out better, but in all honesty I've not heard anything good about those masters. Sure I can flip the bike over using just my middle finger on the lever...but I don't like the mushy part of it.
    As for the chain tool, hope you found one. I don't have one, but if worse comes to worser, let me know and I can possibly borrow one. No job so I can take a ride when ever.
    -1/+3? you don't have the HP I do, but you still got some TQ there. That's crazy. I'm -1/+1 and it's pretty evil
    Jeffersonville, VT
    Thanks slyder! I actually wound up re-using the master from my SV to add a little more slack to the braided lines. I liked the feel of the stock SV brakes, hopefully it's large enough to compensate for the larger pistons.
    I rented a chain tool from RSM when I got my tires mounted up. Managed to leave an axle spacer there though, so it was back and forth a few times
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Concord, NH
    Cool on the chain tool.
    I'm sure the SV master will be more than enough. You liked that master, you'll love it with the stainless lines. I hope you're sticking some decent pads into those calipers. EBC HH pads are crazy and inexpensive. You'd definitely see a night and day difference with the stainless lines and good pads.
    Leaving the axle spacer at RSM is far better than leaving it aside when you put the wheel back on...
    Central VT
    Quote Originally Posted by Slyder27 View Post
    Huh, and I've done both.......
    Jake
    2006 ZX-10R
    Jeffersonville, VT
    Well, I'm glad I caught it when I did put the wheel back on. it slid from side to side... that aint right! Luckily Dan had it in-hand when I called and I was able to get it back.
    Progress made! Bled clutch and brakes, and all controls installed.
    Still to do: headlight brackets, clean up steering damper, mount gauges (or go aftermarket), make/buy fender, rim stripes (), ride the snot out of it!
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Feb 2008
    Las Vegas
    PICS!
    Carpe Diem
    '10 Yamaha R6-Race-
    Jeffersonville, VT
    Did someone say.... PICS!???????
    Photographic evidence of the elusive SV rider in his natural habitat...
    I wish I could leave it like that... still needs the stabilizer, headlight, and gauges on the front end though, that will add a little clutter. I haven't decided whether to go with the flat bars in the pics or put the MX bars back on. Probably will ride with the drag bars for a bit and see how comfortable they are.
    More in-progress pics can be seen by following the link in my sig!
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Superhero F4Iguy's Avatar
    Vermont
    i think you'll love those 16's. I love mine. awesome grip. just gotta stop riding like a girl.
    What?
    Jeffersonville, VT
    Quote Originally Posted by F4Iguy View Post
    Hey now, there are girls that will smoke me 10 times out of 10 on the twisties! I agree though... look at those chicken strips! They take up the whole tire!
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Feb 2008
    Las Vegas
    He's referencing himself David, not you...I've ridden with both of you, and you guys are solid riders!
    Carpe Diem
    '10 Yamaha R6-Race-
    Jeffersonville, VT
    Haha no, I got that- Tyler was keepin up with you pretty good on the way down the gap, I was the one fallin' behind!
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Feb 2008
    Las Vegas
    Are you looking at hittin the track at all this summer? Cause you should!
    Carpe Diem
    '10 Yamaha R6-Race-
    Jeffersonville, VT
    I really want to at some point but its pretty expensive for even a single session.
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Concord, NH
    nice uh, shopping cart
    I think she'll look better with drag bars over MX bars, though they are clearly a few inches lower.
    Do we need to have the grease guard on to pass inspection in VT? I'd call it the chain guard, but if the engine case won't stop the chain, the piece of plastic they call a chain guard sure won't. Actually, as ugly as they are...if that chain is new and you haven't cleaned the white lithium grease off of it, you might want to put it back on till after a few rides....cuz that crap is gonna be every where. Oh how I love new chains
    Cool pics though. Definitely one of a kind you're building, instead of the mass produced assembly line crap I ride
    Jeffersonville, VT
    Inspection?
    But yes, Im pretty sure vt law requires a chain guard only if you have passenger pegs. And mine are not long for this world! Definitely going to clean and lube the chain before i ride though.
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Concord, NH
    So without passenger pegs I could remove the chain grease guard, cuz I have no passenger pegs? Hmm.
    That stuff is a bear. I cleaned mine as good as I had time for and it still flew all over the wheel.
    If you want a good chain lube, that doesn't fly off......go to Ace / Foggs and I think Loews has it to, look for Dupont multi-use spray lubricant. Liquid teflon in a can
    You won't believe how clean the wheel and other parts, including the chain, will stay.
    http://www.webbikeworld.com/t2/motor...chain-lube.htm
  1. Anybody have a chain riveter near Westford, MA?
    By MikeyZ in forum Bike Maintenance
    Last Post: 01-21-13, 12:46 AM
  2. Chain breaker/riveter - Wilmington MA
    By Twheat18 in forum Bike Maintenance
    Last Post: 06-06-11, 04:56 PM
  3. Chain breaker/riveter
    By Variablevalve in forum Bike Maintenance
    Last Post: 05-10-11, 03:41 PM
  4. Borrow chain breaker/riveter near Franklin, MA
    By gamorg02 in forum Bike Maintenance
    Last Post: 03-18-10, 09:19 PM
  5. Chain riveter needed
    By slammp in forum Bike Maintenance
    Last Post: 08-20-09, 03:24 PM
