Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 140
Diary of a custom TW 200 build
  1. #76
    Ginger Twin #2 AHAMAYs2's Avatar
    Montpelier, VT
    Re: Diary of a custom TW 200 build
    This is an amazing project! It's a lot of fun to see what pieces you do next too!
    ____________
    GT2
    What night is Burlington BIKE NIGHT?!?!?!?!?!
    TUESDAY...!!!!!!!!!!
  2. #77
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    The progress continues. Since I was doing away with the plastic side covers, I was going to have to make the airbox / battery holder better looking.
    This just doesn't look good without a side cover:
    One of the aesthetic things I liked about many of the Japanese TW customizations I've seen was "hollow" between the rear tire and seat.
    I got the air filter and crankcase breather taken care of with some cone filters, but still had to find a way to hold the battery. First I looked for the thinnest 12v battery I could find with similar specs to the stock battery. I ended up with an inexpensive battery used for fire exit lighting in buildings. I'm not planning on using the starter (kick start only) so I can get away with a small battery. Might move to capacitor-only in the future.
    Then I played with some cardboard to make a mock-up that would fit inside the frame. I transferred the mock-up to a sheet of metal from Lowes and then made the bends using a piece of wood clamped to the face of my workbench. Not scientific by any means.
    I am a IT guy by day, not a metal worker, so it's not perfect. Rivets hold the corners together.
    From there it went to the oven for a coating of powder and then onto the bike. I'm happy to report that the battery and wiring harness fit completely inside the box. Phew.
    And I like how it's barely visible from the side.
    Around this time, I also did "hitch pin mod". The original setup requires a wrench to free your seat from the frame, which could probably suck if you're in the woods somewhere without many tools.
    This "mod" makes getting your seat off-and-on as easy as pulling two hitch pins.
    You get 2 M6 x 1.00 x 40 bolts from your local hardware store and then cut the heads off. Then you mark where the pin passes through the frame mount and drill a hole big enough for the hitch pin that you also picked up at the hardware store.
    The result looks like this and works really well.
    Also put on some fat foot pegs.
    I then wired up this LED combination tail light, brake light, turn signal unit. I'm not really sold on the way it looks, but it's going to have to work.
    One last thing to do... get the gas tank finished!
  3. #78
    totally righteous.
  4. #79
    Lifer Pittenger5's Avatar
    Austin
    God I wanna build one of these
    Zip Tie Alley #505
  5. #80
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    Awesome work so far! Definitely inspiration for my SR250 build...
    So you still haven't found a home for that mondo toolbox, huh?
    SVenpointsixtwo
    2015 KTM 350 XCF-W
  6. #81
    Lifer markbvt's Avatar
    Georgia, VT
    Awesome. Can't wait to see it done -- and see how it rides!
    --mark
  7. #82
    South Coast MAsshole
    i love this project...awesome work...keep the pictures coming
    Point37s Garage Sale Thread
  8. #83
    Spinner sandros's Avatar
    Dec 2009
    Butte Valley, CA
    Ok, I want to ride this thing SO badly. I wish I had the knowledge and time to do a project like this.
    Maybe this whole med school thing was a bad idea. Certainly hurts my bike addiction.
    - Nothing Witty -
    2002 Ducati 998 (sold)
    2006 Xtreme Pro Stock 125cc (sold to JBell)
    2000 Ducati 748 track (sold)
  9. #84
    something witty here tsanterre's Avatar
    Milton, VT
    looking good dude... got me wanting to take it for a rip!
    ~that which doth not kill me can only make me stronger~
    LRRS / CCS - #103
  10. #85
    Sep 2006
    Colchester, VT
    Thanks for the kind words guys.
    I'm having a hard time tying up loose ends on my TW project because I found photos of this sweet CB the other day.
    It was made by a small shop in Bali and built off of a '76 CB 100.
    Pretty much exactly the same bike as my $125 CB 125 that I've been waiting to restore.
    I was originally going to do cafe-racer type of build but what do you guys think of this? Love it or hate it? Anything you would change?
    BIKE BREAK DOWN:
    · Rebuilt Honda 1976 CB100 Engine bored out to 180cc
    · 88mm aftermarket piston
    · CDI added
    · All engine bolts swapped for stainless steel
    · 4.5 inch chrome headlight from Japan
    · Deus custom headlight bracket
    · Smoked alloy Indicator lights from Japan
    · Daytona speedo and bracket
    · Easyriders ‘Early Tail-light’ from Japan
Ventura “BSA Style” Handlebars
    · Kitaco handlebar controls
    · Clip-on mirror
    · Relocated ignition switch
    · Custom battery housing
    · Brown ‘British ribbed’ -style grips
Front suspension from Yamaha 225, chopped 5cm
32cm ‘Old style’ Yamaha rear suspension
Alloy rims: 18” rear, 18” front, with stainless spokes
Swallow tires, 120/80 × 18 front and same for rear.
Custom galvanized Tank
Custom seat upholstery
Rear frame section modified to accept seat and shortened 3 inches
Hidden horn and rectifier/regulator
    · Front converted to ‘Flower disk brake’
    · Re-wiring of whole bike
    · Original rear hub swapped to Yamaha 225
Custom built Swing-arm made from steel tube.
    That is worthy of a replica, but by all means finish the TW.
    Georgia, VT
    That CB is beautiful. Only thing I'd change that immediately comes to mind is the speedo -- I don't like it offset like that. I'd center it.
    Those tires look great on that bike, for some reason.
    --mark
  13. #88
    Worcester, MA
    hhmmm <wondering> could that be done with a CB200???? interesting
    LRRS EX #165 (formerly)
  14. #89
    love that cb too, but like dude said, finish that tee-dub.
  15. #90
    i agree about the speedo and i'm not really a fan of the rear brake light location...maybe even look a bit better murdered without all the chrome in a flat paint color...either way that looks sweet!
    --mark
  16. #91
    Posting Freak khuygie88's Avatar
    Dec 2009
    RI/VT
    Can't believe I'm just seeing this for the first time. Man, that thing looks awesome! Keep up the good work!
    Dec 2009
    RI/VT
    Quote Originally Posted by catamount View Post
    http://providence.craigslist.org/mcy/1916133227.html
    HOOLIGANZ Icehole's Avatar
    Jun 2009
    Burlington
    BRAVO!
    Sep 2006
    Colchester, VT
    THE FINAL UPDATE!
    I'm done! In other words, my bike is operational and I've been riding it all about. To catch you up on the past couple of weeks...
    The tank color scheme had to go.
    I hit it with some aircraft paint remover in preparation for powder coat. This stuff makes crazy noises while it works.
    Back with a fresh powder coat covering. Notice the new chrome gas cap, which is off of an old vintage Yamaha.
    I found a lady on eBay who sells lots of gel decals. She had Yamaha decals but nothing in a yellow/black combination.
    She agreed to make me custom set for the low, low price of $10. Try getting that deal at your local dealership!
    Once I had the tank back on, it was off onto the roads for my first few miles.
    Before, right side:
    After, right side:
    Before, left side:
    After, left side:
    Maxxis 6006:
    The elusive TW in her natural habitat:
    Where she will live out the rest of her years:
    That's it! Thanks for reading about my build. It was a really fun project, and I learned more than I ever expected.
    Some things still need to be tweaked (headlight won't stay 'tight' after lots of bumps) and tuned (needle and jet need fiddling with after the air and exhaust mods) and I'll probably return back here to report on them as I find out what parts of my build worked, and what didn't.
    In the meantime, though, I'm off to ride this thing.
    -catamount
  20. #95
    Just Registered Doc's Avatar
    Jericho, VT
    Awesome build brother!
  21. #96
    Lifer Expat's Avatar
    Mar 2007
    [QUOTE=catamount;962586]Thanks for the kind words guys.
    I would add a front fender and a small piece of fiberglass around the rear of the seat to give it some shape and color
    Jan 2010
    cny
    awesome work!
    Austin
    God I want one of those so bad
    Zip Tie Alley #505
  24. #99
    just saw your pics on FB and damn that thing looks awesome. great build justin. awesome work.
    So dope. I want.
  1. For Sale - Other | 2016 Trek Slash Size Medium 18.5" custom build - XT M8000 - SAINT - Spank - MRP
    Last Post: 07-18-17, 04:53 AM
  2. Replies: 12
    Last Post: 10-18-12, 09:39 PM
  3. Custom Build: AR15
    By sveesix in forum For Sale
    Last Post: 12-27-11, 05:06 PM
  4. 2001 CBR 929RR Single Sided Swingarm, custom custom custom
    By customfighterer in forum For Sale
    Last Post: 06-29-10, 02:03 PM
