I'm fine with driving and can cage it if i have to, i'm not sure if the 150 will fit, the back tire that's on it now is an AVON 130/70-18
The front tire wich i just replaced is a 110/80-R17 AVON AZARO
wow, a 130? let me do some searching around and see if it will fit. i know that the smallest it will be is a 140, but i thought it was a 150, i'll get back to ya.
I'd stick with an Avon on the rear, since that's what you put on the front. But the Azaro's been discontinued, and its replacement, the Storm, doesn't come in narrow-enough widths. I'd put an AM26 RoadRider on the back, which does come in 130/70-18 and is reasonably priced. I run RoadRiders on my Triumph and have been extremely happy with them.
--mark
Here, allow me to help fix your bike...
Ooops! All done, now you get to buy a new one!
SVenpointsixtwo
2015 KTM 350 XCF-W
yeah, it fits fine on the 90+ fzr rim, but is tight on the 89(which is a 3.5"), i was a half inch off of what i thought the rim was, 140 would be fine, but i;m pretty sure it is a 150. i'll check anyhow, cant hurt.
Hey, my bike doesn't backfire anymore.
I think it'd more likely explode from catastrophic suspension failure from having a 250lb monkey constantly bounce on it...
SVenpointsixtwo
2015 KTM 350 XCF-W
Thanks for the help guys...... and i'm 245lbs thank you very much!
Hey guys, what liquid is leaking out when the header cap is leeking? how safe is my bike to bike if the header cap is leeking?
Header Cap?
what part do you mean by header cap, and what does the liquid smell/look/taste/feel like?
theres just something about a blue bike
Header cap?????
If you mean the head gasket, oil (hopefully). This should be transluscent brownish yellow if it is fresh, blackish if not. If it is grey or foamy then you may have blown a headgasket because that is what it looks like mixed with radiator fluid. Smells like oil.....
Radiator cap: Radiator fluid, alkylene glycol, glycerol, whatever you wanna call it. Usually green or orange. Smells sweet. DON'T TASTE IT. 1 Teaspoonfull is enough to shut down your kidneys and kill you slowly.
Brake fluid reservoir - brake fluid... duh... should be clear or yellowish. Very viscous (means it pours slow and resists movement more then oil or water). Smells like alcohol. Don't get it on your paint.
Glycol is sweet. Brake Fluid is bitter.
And gasoline is tingly.... And not in a good way.
i think based on the description that it must be oil. i forget where i got the term headder cap from but i dunno. Thanks for the help though guys!![]()
So I take it this is your Valve cover? Or your Head Gasket?
Describe exactly where this mysterious fluid seems to be leaking from. That'll make it much easier to narrow this down.
--mark
Or a picture
WTF?
not so much worthless but difficult to diagnose.
KAWASAKI RULES WOOOOO!
I can post some pics tomorrow afternoon when i get out of work. plus i'm riding to freaks house so you can all have a nice look at my baby![]()
