Results 1 to 19 of 19
'00 SV650 Slipper Clutch ?'s
    Lifer Fitz's Avatar
    New Boston, NH
    G'evening,
    I was curious if any of you were running a slipper clutch on your SV at NHMS. Is it worth it or should I just suck it up and learn to be more skilled with my downshifts?
    I guess having a slipper clutch on my streetbike has me a bit lazy on the track.
    Thanks,
    Fitz
    Re: '00 SV650 Slipper Clutch ?'s
    Hi Mark!
    Member davemon's Avatar
    Sep 2007
    Bay Area, CA
    I've never tried one but my SV's clutch is stock and it doesn't give me much of a problem. That said I run stock gearing and don't have to shift all that much as my skil level.
    I figured I woudl reply as I did have a slipper clutch for a while and didn't like it. Mine slipped in both directions though and was casued by me stupidly putting some Castrol 10W40 in... with "sludge protection". That made it REALLY easy to mess up with giving it too much gas and spinning the tire even at near full lean. Doh! When I replaced the clutch pack the old one looked like new aft 5k miles and it was just that damn stuff that made it slip. It is fine now and runs just liek it once did.
    Are slipper clutches getting more common on sport bikes now? Or is it on exotic or near exotic machines?
    Dave
    I've got no problems running a stock clutch on my SV and I don't know many other racers that have them either... especially since it makes us illegal for Lightweight Super Sport.
    First step to smoother downshifts is to not grab a fist full of lever when you pull in the clutch. Bring it into the friction point & let your fingers be the slipper.
    Slippers certainly make things easier if you don't have a smooth technique though, that's for sure.
    smooth schmooth....i just dump it!...well maybe a little slippage into 1. some fast guys run them (Doucette) but no one else i know.
    Quote Originally Posted by davemon View Post
    Dave
    My K6 600 has a slipper on it, as does the 750 and 1000. Most of the big four's SS bikes have slippers on them as standard equipment. I never really used mine on the road, but I know I gave it a workout when I did my LAPS trackday.
    It came in handy going into T1. I still blip the throttle to try to match speed, but the slipper helped a lot, or at least it seemed like it did.
    Lifer Fitz's Avatar
    New Boston, NH
    Thanks all. At $800 I figured I'd ask before I decided to "try" the mod. I have an 07 zx6r that I ride on the street. It was only my second motorcycle and I'm sure the slipper helped me out a few times. Fast forward 3 months and I found myself under or overblipping the throttle on the SV... Turn 1 I was ok (cough... coasting into the corner... plenty of time to spare).. Turn 3 as well as a few other corners I was way off.. probably rushing. With TLR front forks I'm not eligible for SS anyway... Regardless it sounds like I'd be better off spending the cash on a trackday or four...
    Thanks!
    Fitz
    Sep 2007
    Hinsdale, nh
    I don't run one in my sv but # 501 Brian Cooner was running one and he said he liked it .He had a Yo-Yo dine in his
    many a biker have been ruined by a wife and a full time job
    Quote Originally Posted by Fitz View Post
    Thanks!
    Fitz
    Yeah, sounds like ya need to learn how to use the clutch lever as your slipper.
    Don't worry, it takes practice.... so yeah, save your money for track time
    Dec 2003
    Ma
    The slipper clutch is the first thing I will put on any bike, especially a twin or single cylinder engine after braided brake lines and suspension work.
    You're getting a lot of response from people that don't have them telling you that you don't want it. I have one and I'm telling you that it's the best investment after suspension for RACING purposes.
    Any machinists around, I want to make a new pressure plate for my mini with a Surflex style screw based slipper mechanism? : )
    ya got me...
    Fitz, go buy a slipper.
    Member SilverGhost's Avatar
    Essex Jct Vt
    I don't have one but have been looking into them. Hey if its good enough for the GP Moto guys...
    KB KB's Avatar
    Manchester NH
    Doucett must have run them in his SV's because he "didn't really need it"?
    I rode Hessogotaslipper's motard an it's sweet. Coming into three just hammer the shiffter let the clutch work and match the revs. Oh so smooth!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    It definitely takes one more stressor out of the cornering equation. The less you have to focus on, the faster you can go. modulating the clutch to control wheel hop take a LOT af your attention, not to mention that it's focusses attention at the back of the bike. That's a recipe for going slow IMO.
    Does a beginning track rider need it? I don't know. I suppose that starting off with one will help you go faster sooner.
    Essex Jct Vt
    I am no pro but it sounds like you answered your own question.
    Meriden, Ct
    Dave
    GSX-R's have come with a slipper cluch as a stock item since 2005 (1000)
    Lifer Fitz's Avatar
    New Boston, NH
    For what it's worth I did opt to pick up a yoyodyne slipper clutch for the SV over the winter from Souhegan Valley Motorsports. Really slick pricing. Install was smooth even though the directions weren't the best. Since then I've put in ~18 or so practice sessions and three races with zero maintenance issues. Frankly, I love it. It absolutely gave me more confidence in the corners as I had less to focus on. I'm entering T1 & T3 much more comfortably and have dropped ~10 seconds from my lap times (1.36 -> 1.26.X). Sure I don't credit the slipper for all of that but it really is a nice to have.
    Fitz
    Word
    Buy me one now?
  1. Wanted - Parts & Tools | Sv650 slipper clutch - gen 2
    By cbrace in forum Wanted
    Last Post: 07-02-19, 08:57 AM
  2. For Sale - Parts & Tools | Yoyodyne slipper clutch, Ducati 848 wet clutch
    By jwm2k3 in forum For Sale
    Last Post: 04-27-17, 10:07 AM
  3. Slipper clutch install-- SV650
    By Charlief in forum Bike Maintenance
    Last Post: 09-09-10, 01:16 PM
  4. i need a slipper clutch!!
    By landricscustoms in forum Wanted
    Last Post: 05-19-10, 09:02 AM
  5. Slipper clutch VS. ???
    Last Post: 02-08-06, 09:17 PM
