Results 1 to 16 of 16
1st gen sv bellypan
    go faster cdovego's Avatar
    Weymouth
    1st gen sv bellypan
    What's the hot setup on a naked 1st gen?
    Looking for 1 step above the turkey roasting pan with safety wire hack.
    Called Woodcraft, assumed they'd have something - no such luck.
    Central Mass Powersports #123
    Re: 1st gen sv bellypan
    You can pretty much take any race lower from any bike and make it fit.
    Tons of mounting points on frame, radiator, etc. couple aluminum brackets and you are set.
    Trust me if I made it seem easy, it really is easy.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Slightly off topic but if you want to go full fairings I have 2005ish 749 Ducati upper and lower you can use if you go a different route.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    You can easily make that lower work
    Weymouth
    Def. take you up on that further down the road, let's let him get all the crashing out of his system before we make it pretty.
    May 2010
    Somersworth, NH
    If you need a spare bike also my gen 1 will be up for grabs soon...
    Weymouth
    If I understand correctly, you're saying I need a carton of cigarettes and a Panos?
    Thanks, could use a spare set of wheels - already scored Sam's b bike as a spare.
    Windham NH
    Yoyodyne used to have a pan for a 1g. Looks like their bodywork is now made by sebimoto. I see an SV pan listed on sebimoto's site but not yoyodyne's.
    Fairing for Motorbike Suzuki SV 650 S 00 - Oil Tub
    Suzuki Fairings
    Even less than that lol
    Weymouth
    1st gen sv bellypan-dumpster-fire-jpg
    How this story ended, 999 (?) belly pan donated by TAS.
    Haverhill, MA
    Is there enough clearance so that if the front compresses completely that the tire does not hit the belly pan and break it off somehow? Think turn 10 transition compression.
    Weymouth
    I'll look over it in person this weekend. Jimmy put it together for us and he races so he gets the details like we do. Tough to tell from the picture but my gut says he accounted for it. Will def. make sure before we send young Jack out for rd. 1.
    Sep 2013
    Jaffrey NH
    clearance was a concern when i mocked it up on my 2nd gen SV but not the reason why I am not going to use it. My main concern was getting a fairing stay for it. The vortex SV stay sat too high and I was not about to start bending the ears.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Weymouth
    The upper would've required being hacked away so much it just didn't make sense.
    Sep 2013
    Jaffrey NH
    Hack away if necessary.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Jesus. Rule book says belly pan must catch 3 quarts of fluid, not 30!
  1. For Sale - Services | 6” Race Numbers for Bellypan, Nose, & Tail $15/plate
    By kumpy in forum For Sale
    Last Post: 05-14-18, 11:06 PM
