Page 9 of 10 FirstFirst 12345678910 LastLast
Results 201 to 225 of 236
Braking technique advice
  1. #201
    Re: Braking technique advice
    Can someone explain blipping the throttle if its not already been discussed, havent read the whole thread yet?
    Is this a serious question? (never know with gingers)
    Blipping is simply giving the throttle a quick partial twist just as you pull the clutch and downshift. The purpose it to attempt to match the engine RPMs with the downshifted RPMs.
    Basically, it prevents that jolt you get if you simple stomped down a gear.
  2. #202
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    I usually just stomp a downshift without touching the clutch, and I dont think I touch the throttle either. Just brake and downshift. Though Im braking well before I downshift, so maybe the engine speed is more matched to the next gear down? Is that how it works?
    Yes. So it is smoother.
    Lifer Pittenger5's Avatar
    Austin
    Are your downshifts choppy or smooth? Can you downshift while leaned over & not have the rear step out on you unpredictably?
    They dont seem too choppy. Pretty smooth actually, other than the increase in engine braking. I dont downshift leaned over, but I wouldnt feel uncomfortable at this point doing it. The only place I downshift even remotely leaned is 1, and Im done shifting before I REALLY toss it in.
    have you seen Rickie ride?!?
    *shrug*
    Quote Originally Posted by 07BladeRider View Post
    Totally serious. I do a ton of stuff on the bike that I dont realize I'm doing it (like trailbraking) without someone telling me, or I do things I shouldnt be doing and develop bad habits that are a bitch for me to break (piss poor body position)
    Zip Tie Alley #505
  4. #204
    Nov 2007
    You don't grab a downshift in 11? I grab two usually on the tard I think, but you have a 4spd...
    I come out of 10 in 4th, grab 5th, then drop two through 11, then onto straight
    Zip-Tie Alley Racing
    LRRS/CCS #103
  5. #205
    Werd, Richie ain't no slouch!
    But once you start braking harder & harder the rear may start to break loose a bit when you grab those downshifts as there's gonna be a little less weight back there... this is where clutch modulation and/or blipping will help you (unless you have a slipper, in which case that'll probably kick in).
    So you aren't downshifting while leaned over for 11? Go in deepah! I see a lot of the motard guys downshifting with their knee awfully close to the pavement.
  6. #206
    Nov 2007
    +1... richie you're already getting quite quick, I'm surprised you're not doing what pete and I said in 11. That means you have some time there that you could easily recover, and get yourself some 21's son
    LRRS/CCS #103
  7. #207
    Austin
    Quote Originally Posted by ceo and a bunch of numbers View Post
    I grab 2 in 11, but Im still relatively straight up and down when I do. I brake at the seam, bang 2 downshifts and toss that bitch in!
    Zip Tie Alley #505
  8. #208
    At the seam! The brake marker is the cone on the left!
    Nov 2007
    That is early Richie... you can easily pick up some time there. I mean no, don't, then you will be faster than me. Nevermind.
    LRRS/CCS #103
  10. #210
    Austin
    Yes, the seam at the cone on the left, thats what me meant.
    Zip Tie Alley #505
  11. #211
    Ya dude, the second seam is my roll-off point & my bike's a Scotty compared to your Kate Moss.
    Try holding it WFO past the seam.
  12. #212
    I don't think we're talking about the same cone. There are 2 seams(cracks) that run across the pavement. Then there is an apex cone at the left well past the second seam. then a cone on the right near the curbing/jump. If you hold the gas open to the first apex cone, you will be knee down going into the braking zone with no way to straighten the bike up much before shifting. This is the real reason for the different lines I was talking about.
    Most guys will roll off at the seam which stands the bike up into the braking zone. Really fast guys will stay on the gas well past the seam, requiring them to stay leaned left into the braking zone.
    Edit: this is even true for a 600 Pete. You need to stay on the gas too!
    live to ride seth399's Avatar
    Feb 2007
    CA
    richie posted up a medal!
    I have no idea what seam you guys are talking about...shit
    LRRS #399
    MX #505
  14. #214
    You might not even be getting close to the seam yet. When I cross it WOT, it's a big enough hit to light up my front end with a slapper! When you cross it on the brakes, your front end is able to just absorb without you even noticing.
    Austin
    Hmm, I will hafta investigate, whos got some good onboard that shows that area.
    Zip Tie Alley #505
  16. #216
    This one shows the seams clearly. It actually shows more detail than my eyes can pick up. The crack you can see in the vid at the apex cone is not really noticeable while riding. It's way too small.
    http://www.youtube.com/user/rcuchyahoocom
    Whoa, I fail.
    Feb 2009
    Lost in constant migration
    Whoa, I fail.
    Nothing like some expert video to show just how much I suck! Great video though (especially in HQ), thanks
    I'm amazed by people who look back at race pace... especially taking a hand off the bars over the hill. Do many of you do this? The only people I see doing it are Penguin instructors. I'm convinced if I did this it would end catastrophically.
    Quote Originally Posted by Paul_E_D
    I'M TRYIN PAUL! I should have said ''was'' my roll off point. I'm holding it open past the seam & almost to the cone on the left now
  19. #219
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
  20. #220
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    The new issue of Sport Rider has a nice article about rev matching. It doesn't talk much about trail braking but it does tie into this discussion quite well.
    LRRS 878 Clapped out Gixxah
  21. #221
    Lake Champlain, VT
    I think since there are so many "seams" at Loudon, we should just line it like a football field so we can rever to which yard line we use for braking point
    Ha! Yeah, but in your vid it's more obvious. The Hi Def camera, like in the link I posted, show way too much detail. There are 2 full length cracks that run 90 degrees across the line going into T11. Most people use them as reference points. It looks like you do too, as you rolled off just before the second seam.
    Feb 2007
    CA
    ahahaa I fully support this.
    LRRS #399
    MX #505
  24. #224
    Oct 2005
    Wrentham MA
    the seam is a good goal to shoot for at track days - move it fwd in minute steps is also cool.
    Graham
  25. #225
    Member bdawkins20's Avatar
    Cape Cod Ma
    Thanks kitt! I can honestly say I am sitting up straight while braking and banging down gears while going into 11. Its just one of those little things that will most likely save a sec or two! Def. neat to see how the fast guys do it!
    AM#220
    99 cbr 900 street
    02 sv 650 race
  1. Braking bumps
    Last Post: 10-21-12, 11:31 AM
  2. braking
    By Marc R in forum General Bike Related
    Last Post: 08-01-12, 02:26 PM
  3. downshifting while braking
    Last Post: 08-25-07, 12:39 AM
  4. Braking/cornering Q.
    Last Post: 02-15-06, 07:41 PM
  5. Can you say late braking????????
    By Rye in forum Pit Area
    Last Post: 06-24-03, 09:37 AM
