Did a little assembly this weekend. Got the forks done. Still waiting for the triple clamp to be made so they are off to the side. Swapped out the stock pegs for a pair of moose pegs. The moose pegs are wider, have a more aggressive tread, and have a slight convex shape to make it easier to move on the bike. I decided to pull the shock. In addition to pulling the shock I did the exhaust. The way the bike is built you need to both at the same time. Ill get some shots of the stuff on the bike hopefully later today.
Stock exhaust
After market
Both are made by akrapovic and both headers are titanium. The stock weighed 6lbs and the after market weighed 4lbs. The 2lbs weight savings was all in the muffler. I think its nuts an entire system can weigh 4lbs including the steel flange used to hold the pipe to the motor which is probably close to 1lb itself.
