Results 1 to 24 of 24
Drill or dremel tool better for drilling bolts?
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Just wondering if the super-high speed of the dremel would make drilling holes for safety wire easier or harder.
    LRRS 919
    Re: Drill or dremel tool better for drilling bolts?
    Best way is a Drill press with a nice holder, fresh Ti bits and some tool oil....goes like BUTTA...
    Apr 2011
    NH
    and use a low speed
    Tim
    LRRS #44
    Superbike Services 44
    Windham NH
    Or you could do it with an 18v hand drill and a bunch of cheap bits from HD. Its about a 4 beer job that way.
    and let the drill do the work dont hammer it you will just break bits... as i did LOLOL
    Jun 2005
    Lifer ZX-12R's Avatar
    Candia, NH
    Also great for breaking glass in an emergency!
    Rocky Hill, CT
    Piggy nailed it. Low speed drill press, Ti nitride coated bits and some cutting oil. Piece of cake.
    I'm a monumental cheapskate, but even for me.. WD40 is not cutting oil.
    go faster cdovego's Avatar
    Weymouth
    I found using a punch prior to drilling to be extremely helpful.
    Central Mass Powersports #123
    Sep 2013
    Thanks, Tricky. On another note, I just posted another thread about what brand / material clutch to put in the KaTooM. Do you have any thoughts there?
    LRRS 919
    Jun 2005
    One that slips if you can spare the loot
    Sep 2013
    Perfect. The one I have slips just fine.
    LRRS 919
    or just forget the drill and get these http://www.probolt-usa.com/stainless...race-spec.html
    Drill'em. You'll feel better about yourself for doing it.
    Be a man for Christ'sake.
    Jims a girl.
    KB KB's Avatar
    Manchester NH
    Don't use those special to or cobalt bits. Just get some good old bits for drilling metal. You want them to flex not break.
    Patience and slow speed and cutting oil.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Sep 2013
    Any suggestions for cutting oil?
    Amazon.com: cutting oil
    LRRS 919
    Jun 2005
    Any of those will work just fine.
    A little X-Y vise and a drill press make the whole process MUCH easier if you have the space for it. A Bridgeport is even better.
    Sep 2013
    I can speak to your experience with drilling safety wire holes. I think you drilled every bolt in that KTM - must have been a really long winter
    I think I'm going to start calling you Meticulous Mike. I don't know what you fed that bike but the guy that helped me with the top end said it looked like the hone marks were still there from the factory - that engine is like what, 12 years old?
    LRRS 919
    May 2011
    Holyoke, MA
    Solid carbide drill bits and center bits, hydraulic work holding vice with spots for 10 bolts, CNC mill programmed to drill a hole in each head. Clamp it, push the button, 10 safety wire drilled bolts!(+100k in equipment.). Just make sure to use coolant and get the feed and speed right. You want to center drill then drill with the bits.
    Jun 2005
    Yeah, I never had any money growing up. That was the first new car/bike/etc I ever owned. It got its share of love
    Anything that's actually cutting oil should do fine. WD40 is not cutting oil
    Sep 2013
    Word. Ordered a bottle of the dark shit based solely on cost / oz.
    LRRS 919
  1. Drilling bolts- how many holes?
    By Petorius in forum Pit Area
    Last Post: 04-22-14, 12:31 PM
  2. Drilling Fasteners for Lock Wire
    By DanRo in forum Pit Area
    Last Post: 04-02-14, 07:39 PM
  3. need drilling for safety wire?
    By Kitt in forum Pit Area
    Last Post: 05-06-08, 01:18 PM
