Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Drilling Fasteners for Lock Wire
    Re: Drilling Fasteners for Lock Wire
    Sent: Tuesday, April 01, 2014 11:51 AM
    To: 'Jim'
    Subject: RE: exhaust header bolts
    No Market for them no other race organization need them
    Sent: Tuesday, April 01, 2014 10:42 AM
    To: ProBolt
    Subject: Re: exhaust header bolts
    that’s why I asked why you guys don’t offer the header bolts pre-drilled.
    is there just not a market for them, or is it difficult to machine to the pre-drilled holes?
    Posting Freak Gecko's Avatar
    Jul 2008
    To: 'Jim'
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    #331 CBR929RE's Avatar
    Bridgewater, MA
    yeah I could take off all the nuts on mine and the chances of the headers going anywhere are still pretty slim. the whole system was a good pain to get it all together and on the bike in the right place. took some work to get everything lined up just right where the pipes all fit into each other and into the cylinder head. plus all the nuts are under tension from the flanges so if they back off then you really did something wrong in the install.
    Jul 2008
    ....plus all the nuts are under tension from the flanges so if they back off then you really did something wrong in the install.
    "Never underestimate the power of human stupidity." - Robert A. Heinlein
    John
    CCS/LRRS Expert #69
    The nuts shouldn't be under THAT much tension from the flanges. You're pressing into some form of a compressible gasket, which isn't springy. Typical header nut torque is pretty low too, add thermal shock and expansion/contraction and at times I'm amazed those nuts stay on in the first place. (7.2ft/lbs on my machine for example.)
    Jul 2008
    ....Typical header nut torque is pretty low ... (7.2ft/lbs on my machine for example.)
    Yup, the R6 is 15ft/lbs.
    John
    CCS/LRRS Expert #69
    16.5ft/lbs for the GSX-R's
    ive never done those. never did i not pass tech. although they are probably so rusted on anyway. theyve been there since 2001.
    WMC original sdog30's Avatar
    Burgy
    I always just wire the two header bolts to each other and yeah it's only the header bolts on the outside that need to be done on an r6. Save yourself some headache, John and just go to the dealer and buy 4 new bolts. Million times easier than drilling hardened used header bolts.
    LRRS/CCS #66
    Large member Larry's Avatar
    Nov 2010
    Limington maine
    Usually there is enough thread left on the header stud to double nut it with lower grade hardware that can be easily drilled before hand. Unless of course you have bolts instead of studs.
    Jul 2008
    Have you gotten them locally or online? If I go locally, they may come in by August . . . 2015.
    John
    CCS/LRRS Expert #69
    Burgy
    Quote Originally Posted by Gecko View Post
    I just went to valley motorsports.
    LRRS/CCS #66
  1. Drilling bolts- how many holes?
    By Petorius in forum Pit Area
    Last Post: 04-22-14, 12:31 PM
  2. need drilling for safety wire?
    By Kitt in forum Pit Area
    Last Post: 05-06-08, 01:18 PM
