Results 1 to 23 of 23
Motard Suspension setup help...
    Just Registered Doc's Avatar
    Jericho, VT
    Ok so I have the 450x in motard trim with the stock suspension...
    Without putting any money into it what can I do to the suspension to make it better as a motard?
    Add Fluid? Raise the forks in the tubes? Stiffen it up all around?
    Does anyone have some base suspension settings to go with?
    Re: Motard Suspension setup help...
    Ask On supermotoJunkie
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    Doc, i know oil weights will have an impact as well as levels. I raised my forks in the tripples a little. are you bringing it to the track for the last weekend?
    Give it to me. I felt more comfy on yours than mine own.
    Oct 2007
    Littleton NH
    What are you racing?
    560smr
    Feb 2004
    Bellingham, MA
    Leave it on the stand.
    Hah, as funny as that is, Mr Kates is on point. The front brake will cook off WAY before the suspension slows you down.
    Jericho, VT
    I shoulda known this was coming from you...
    Jericho, VT
    I have the bigger brake rotor.
    From
    My limited experience the only thing I can do with the stock stuff is slow the rebound. That way it doesn't pogo when you flip it. But then your just masking the problem, sorta.
    I have the bigger braker rotor.
    Doesnt help that much. My brakes still get a ton of fade after just a few laps
    Your 450X has cushy woods suspension vs the stiff MX suspension of the 450R...you're pretty much screwed because the springs are so soft. or should I say, at least IMO
    Martire and his crew are going softer and softer on their motards and claiming its great. They were talking about bottoming a crf at loudon last time I was there. I don't think I could ride one that way. I like a bike that doesn't transfer much weight for and aft.
    Jericho, VT
    Good info there. Thanks.
    live to ride seth399's Avatar
    Feb 2007
    CA
    jack the compression adjusters so it doesn't dive under braking....other than that just ride the pig
    LRRS #399
    MX #505
    Dec 2006
    Quote Originally Posted by seth399 View Post
    we all know how much you love riding pigs.....
    Feb 2007
    CA
    Quote Originally Posted by lawndart View Post
    YOU will die in your sleep at my hands!
    LRRS #399
    MX #505
    Dec 2006
    so what your saying is you're going to touch me in my sleep? ....I'm leaving.
    Jericho, VT
    Quote Originally Posted by MysteriousR1 View Post
    Ok then, I am not going that fast.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Get a notebook, pen, and tire gauge. Set your sag. Make a large change in fork dampening and see what you think. Make a note. Then go the other way. Make a note. Then play with the rebound. Then play with the rear. Taking notes as you go. Slide the forks up and down and feel the difference. Even if you cannot do much at least maximize what you have. Then when you finally wish to make improvements and you see Pete you can communicate with him in a knowledgeable fashion about what you are trying to accomplish.
    No, I am sure your going faster. I am not sure if it is just a KTM thing but I have heard that the stock caliber sucks when you start to use heavy breaking often. There were track days when in the AM brakes were awsome, by lunch I was bleeding.
    Jericho, VT
    No seriously, I instruct with it in the beginner/red group. I am not going all that quick on it (slow intermediate pace) and I am certainly not braking all that hard. There is PLENTY of squish in my lever as well, It is good to note that a caliper upgrade might be in order. Thanks.
  1. Suspension setup..
    By cdseven95 in forum General Bike Related
    Last Post: 05-12-10, 02:47 PM
  2. Is there anyone who can help me setup my suspension?
    By hohum in forum General Bike Related
    Last Post: 08-02-02, 08:50 AM
  3. Suspension Setup
    By Chuck in forum General Bike Related
    Last Post: 05-01-02, 01:04 PM
