What's the best setup for a quickturn throttle on an SV? I have a bad wrist and the throttle throw on this thing is wicked long, not to mention the bike doesn't have a ton of power so I'd like to be able to get to WOT quicker.
I found this writeup on using an r6 throttle, so I ordered the part since it's so cheap. It says for a gen 2 you need to cut some plastic but for a gen 1 it's just a plug and play solution. It doesn't say what the throw is but I'm assuming it's better than stock (and I'm assuming mine is still stock):
R6 Throttle Tube on the SV650 | Canyon Chasers Motorcycle Sport Touring
I was going to buy the motion pro kit with the cams (had been planning for this on my r6 too), but apparently motionpro doesn't make it for the gen 1, only the gen 2.
Then I found TWF Racing, some guy Zoran, makes stuff and he sells what I assume is a modified motion pro kit with an extra kill switch (maybe that's why motion pro doesn't sell it, the stock setup is integrated). A little spendy but if it would work better I don't mind.
TWF Racing Parts
Would that one be able to get an even shorter throw than using the r6 tube?
or any other solutions...
