Results 1 to 13 of 13
Gen 2 SV650 power loss in the rain.
    Senior Member Philkinson's Avatar
    Jun 2012
    Warwick, RI
    Hey guys,
    Yesterday at NHMS I was out during one of the wet races and my motor lost any power it had. Limped it into the pits... I've found some info online about a clogged drain for the front cylinder. Is there a remedy for this once I clean out the drain? Any sort of... shield?
    Thanks!
    now retired LLRS AM #642
    Posting Freak Scottg22's Avatar
    NH
    Clean out drain and replace the plug cap... be sure the seal is in place the best it can be. Plug caps seem to be a pretty regular failure in the rain. I tried to have a spare for Sam's SV
    Re: Gen 2 SV650 power loss in the rain.
    X2 drain hole and new cap problem solved
    Jun 2012
    Warwick, RI
    thanks guys!
    Ah, the infamous SV325.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Jun 2012
    Warwick, RI
    And here I was thinking I couldn't get any slower!
    Hanover, NH
    So what you're saying is, he can run it against R3s and RC390s?
    Seacoast NH
    Paging Kurlon.
    Gotta keep yer drain hole clean!
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    i had that happen once. i think pete passed me and gave me a wtf look
    problem went away when i installed a fender
    edit: just realized you said 2nd gen, didnt those have a plastic flap that covered the front spark plug?
    Paging Kurlon.
    CCS single cylinder blind spot gets you into just about every class other than anything Supersport, Supertwins, or Formula 300. You can run Ultralight 300 but your points will not count for the ROC in Daytona as you'd exceed the 310cc limit on singles in Ultralight Thunderbike.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Lifer golden chicken's Avatar
    Fitchburg, MA
    Yes, but that little flap doesn't do enough if it's wet enough. Water can still get through the radiator (and around the flap) and down onto the front plug.
    I loled
