It sure sounds like you ran out of ground clearance. Can't comment on your body position, but that might have been a factor.
Definitely a lazy turn-in. A delayed/quick turn-in gets the bike turned quickly and means that you are at max lean for a shorter period of time. It also means that you can get on the gas sooner, which helps to increase ground clearance.
