Results 1 to 25 of 33
Middleweight Supersport - How light can you go?
    My 03 R6 is a pig compared to the machines I'm used to hustling around the track. I haven't weighed it yet but it's gotta have a good 100lbs over my 400. Granted, that's comparing a full superbike machine from the way simpler carb days to a EFI setup supersport, but still, that R6 is heavy! What are people hitting for weights in CCS supersport legal configs on their middleweights?
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Massachusetts
    Re: Middleweight Supersport - How light can you go?
    370-380 is common
    Lifer Pittenger5's Avatar
    Austin
    Just wait till you shoehorn the busa motor in there, then itll be a real pig!
    Zip Tie Alley #505
    Ok, so I'm not that far off the mark then I suspect. Just going to have to hit the stair master more before pushing it up the ramp again.
    You've got me curious as to just how much more a 'busa mill weighs compared to an R6... quick, to the eBay to compare shipping weights!
    Looks like the R6 is in the 120lbs range, 'busa in the 180lbs to 200lbs range. That's a lot of extra pork for that extra go...
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    According to Honda the 1200 vfr motor was significantly smaller than the 800. And had nearly 70 more hp.
    Austin
    And this, for those unfamiliar with Kurlon, is the point at which it starts. Its like a Kurlonization Big Bang!
    5 Not allowed! Not allowed!
    Zip Tie Alley #505
    Quote Originally Posted by Woodcraft View Post
    370-380 is common
    What's the number change to if going all superbikey?
    365 maybe. lol
    What the hell? Where is the lead in there so I can get it all out?!
    Sep 2007
    Isn't the 2007 CBR600RR one of the lightest, something like 407 lbs wet weight and much less with a few simple mods?
    Street Triple R, Ducati Scrambler Icon, Monster 1100evo, VFR, CRF250L/M, CRF230L
    In your case, strip it to the frame, cut everything off that is non essential, fab a CF subframe, strip emissions crap, new faring stays and fairings, new wheels, lightened rear rotor, strip wiring harness, remove starter and magnets, lighten flywheel, a few aluminum clutch plates, lightwieght chain/sprockets, titanium shock spring, titanium bolt kit and maybe you get below 400. Maybe.
    You would then have something nearing the price/worth of the WReck, But you weigh so little that the bike probably isn't that far off of your competition stock vs stock.
    Meh, now that I know everyone else is having to throw the same piggie around, I'm just going to keep it SS. Lightweight batt, keyswitch eliminator, annnnnnd... done. Subframe costs real money, exhaust costs real money, other than stripping the harness and de-tabbing the frame the other big ticket stuff has already been tossed.
    Seacoast NH
    So a 3-way stable now? FZR -> UL, WR -> 'tard, R6 -> MW...
    Look at you mr bigtime!
    Four way, I've raced the KTM and will again if the right opportunity presents itself.
    Seacoast NH
    Well, if Stimilon counts then I get to call my ol' DRZ a podium finishing machine..
    JACKASS hammadown's Avatar
    Hopkinton, MA
    ...I'm just going to keep it SS. ...
    As much more epic as this would have made that thread, thank Jesus!
    Zip Tie Alley #237
    Hanover, NH
    What KTM do you have? I genuinely can't remember
    Seacoast NH
    I'm going to go out on a limb and guess "2009 XC-W 300"
    xxaarraa
    Guest
    Josh is in the middle of a spendy period. 4 bikes, motor home...
    Loan me $5k, don't expect payback, and I'll have center 15 battle station for Sept!
    Quote Originally Posted by hammadown View Post
    Are, are you trying to egg me into GP land?
    When has anyone ever had to "egg" you into GP land...
    Senior Member MFChop's Avatar
    Apr 2014
    Nashville, TN
    My old '05 was in the 365ish, my '15 is 375ish both could still go lower too. There was a guy with an 05-06 636 who got his in the 350 range with your typical off the self parts, stripping the non essentials, and aftermarket wheels
    Hopkinton, MA
    This Middleweight Supersport - How light can you go?
    Sent from my SM-G935V using Tapatalk
    Zip Tie Alley #237
