Ok so I have the 450x in motard trim with the stock suspension...
Without putting any money into it what can I do to the suspension to make it better as a motard?
Add Fluid? Raise the forks in the tubes? Stiffen it up all around?
Does anyone have some base suspension settings to go with?
Ask On supermotoJunkie
Zip Tie Alley Racing #444
Signature edit by Tricky mike
Doc, i know oil weights will have an impact as well as levels. I raised my forks in the tripples a little. are you bringing it to the track for the last weekend?
Give it to me. I felt more comfy on yours than mine own.
560smr
Hah, as funny as that is, Mr Kates is on point. The front brake will cook off WAY before the suspension slows you down.
From
My limited experience the only thing I can do with the stock stuff is slow the rebound. That way it doesn't pogo when you flip it. But then your just masking the problem, sorta.
Your 450X has cushy woods suspension vs the stiff MX suspension of the 450R...you're pretty much screwed because the springs are so soft. or should I say, at least IMO
A Big Powerful Sportbike
Martire and his crew are going softer and softer on their motards and claiming its great. They were talking about bottoming a crf at loudon last time I was there. I don't think I could ride one that way. I like a bike that doesn't transfer much weight for and aft.
jack the compression adjusters so it doesn't dive under braking....other than that just ride the pig
LRRS #399
MX #505
Get a notebook, pen, and tire gauge. Set your sag. Make a large change in fork dampening and see what you think. Make a note. Then go the other way. Make a note. Then play with the rebound. Then play with the rear. Taking notes as you go. Slide the forks up and down and feel the difference. Even if you cannot do much at least maximize what you have. Then when you finally wish to make improvements and you see Pete you can communicate with him in a knowledgeable fashion about what you are trying to accomplish.
No seriously, I instruct with it in the beginner/red group. I am not going all that quick on it (slow intermediate pace) and I am certainly not braking all that hard. There is PLENTY of squish in my lever as well, It is good to note that a caliper upgrade might be in order. Thanks.
