Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
New Motards
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Re: New Motards
    Re: the TM they look great but I'm a little hesitant to race something that no one else is and that's imported - replacement parts, trouble/issues, getting aftermarket stuff, etc... is that an issue with these? I guess I'd want to know if they will be a better weapon (significantly) than the husky to make any headache worth it. What's the powerplant?
    Thats what I am worried about. It seems that parts are fairly easy to get from TM directly and more and more dealers are getting involved with TM. It is probably not much more of a headache unless you broke something at the track and need parts immediately, it's unlikely someone will have spares. As fas as it being a weapon, the bike is probably as good out of the box as a setup FS/KTM/ whatever. Most people aren't riding the FS stock.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Lifer loudbeard's Avatar
    Re: New Motards
    I don’t know how anyone could buy a vehicle from a manufacturer with a website like that. It’s atrocious.
    WMC original sdog30's Avatar
    Burgy
    Re: New Motards
    I bought a TM this year. I love it. Haven't had a chance to try it at Loudon yet, though.
    Kevin Allen has a dealer connect in Vermont. Also, Jay Klinger from smec is putting in a dedicated trailer at ovrp in NY if that helps.
    14 Triumph Street Triple R, 15 KX450F sumo, 15 Husky 250SXF tard, 14 KTM 250SXF and Cole's Grom
    LRRS/CCS #66
    Re: New Motards
    The TM has geometry specific to SM that the FS/SMR do not. The FS/SMR are literally KTM 450 SXF bikes with different clamps, tweaked valving fork and shock. The TM is a dedicated frame and swingarm, you're not matching that with an FS/SMR without a cutting torch and welder.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Burgy
    Re: New Motards
    Starting price for one new is about $12.5, but when you look through the price sheet, that price goes up quick.
    Get the Ohlins and electric start at a minimum.
    LRRS/CCS #66
    Nov 2007
    Re: New Motards
    Is aftermarket stuff easy to get?
    Also what are people doing with the FS - thought it was pretty ready to go. (then again i'm just an amateur)
    Quote Originally Posted by tucktuvak View Post
    The service from TM is awesome actually, I just call or email Ralph at gravity TM racing (the US distributor) and order whatever I need. They have an online shop now too. Usually ships FedEx the next day. There is one guy racing a TM in LRRS. Power plant on the kit 450 smr is a factory race 65hp 450 4t. Check the price list on the TM website, but I do see those fs450s are starting to get cheaper, for some reason I thought they were like $13k.
    http://www.tmracing-usa.com/2021/202...20Customer.pdf
    That looks like the street list. This is the racing model list and starts at 12.5 like folks said and very quickly gets above 16k with suspension electric start 6 speed gearbox etc... http://www.tmracing-usa.com/2021/202...list%20SMX.pdf
    Who makes the motor? Or is it an actual motor made by TM. That's what worries me a bit. Vs. the KTM plant that's in the FS/SMR that are a dime a dozen with relatively proven reliability.
    Kurlon - i know you say SM specific geomety but i'd be mostly roadracing it (i think) so wondering what's the best for that. If the answer is still the TM then great, but 80mph knee down in turn 9 is pretty different than foot out backing it in at 40mph....
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Re: New Motards
    If you look at the places TMs normally compete in Europe, they do get thrashed on some pretty big tracks, and their riders do road race some corners vs nearly always trying to back'em in like US sumo riders do. Now, I've only done a couple tame lap's on Sam's machine, pavement only on a tiny track but what I immediately picked up on is it has the corner carving stability of my WR250, which is WAY biased towards road racing with how I built it. (Basically made it a hot mess for short track.) At the same time, it's got damn near telepathic flick-ability like my MX bike on 17s 150 SX that has had nothing changed setup wise other than slapping 17s on it. (It does NOT like to carve corners, full stop.) No chatter when carving BUT you don't loose flick-ability, just monkeying with clamp offset isn't going to get you that combo it requires rake and wheelbase changes which KTM hasn't bothered with since the last 'real' SMRs in 2012.
    Clearly the modern FS / SMR can put up a good fight, and people know how to set them up to do well at NHMS. My gut says the TM should be able to out handle them, a bit more flickable with less chatter/drama while doing so, but I can't say for certain from first hand experience on one at NHMS but on paper the numbers seem to be there.
    On the motor front, TM makes their own motors, right down to the base castings.
    Burgy
    Re: New Motards
    At a minimum, you'll have to do the suspension on the fs. Other things you might want is quick shifter, and an exhaust/tune. Once you go expert, you'll probably need engine work as a 19 is mid pack now.
    LRRS/CCS #66
    Nov 2007
    Re: New Motards
    Thanks guys. Definitely have analysis paralysis at this point. Options are basically
    '20 FS 10k (but would need a few grand of stuff)
    '21 FS 11k (but would need a few grand of stuff)
    '21 TM 16k fully kitted out with their options
    ETA: no, i don't want a front wheel drive car with snow tires
    LRRS/CCS #103
    Fairhaven, Ma
    Re: New Motards
    The TM is fantastic. Go with a 16.5 unless you only want to run Michelin, they have the only 16” available.
    If you don’t mine me asking, Who would you order from?
    LRRS EX 151 AMSOIL
