Results 1 to 25 of 33
Anyone ever used this stuff in their track/race bike?
    Saw this on the WERA site. It's called Anti-Slosh Fuel Foam. It's supposed to dissipate the effects of your fuel moving around in your tank, especially upon heavy braking.
    What happens when it starts tp break up? Does it end up in your fuel system?
    More info here:
    http://forums.13x.com/showthread.php?t=238673
    Its for little bikes like 125 GP bikes
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Anyone ever used this stuff in their track/race bike?
    I ran it in my racecar and changed it every 2 years.
    Posted by Jane in BoxChat
    It was in my 125 for over 10 years. Never broke down. It's good in any bike that has a top heavy fueltank. Not JUST small bikes. The MuZ needed it for example, and I bet some motards would benefit. Basically if you sit on your bike with 3/4 tank of fuel and rock it a bit then relax and you feel it continued to rock, then you can benefit from it.
    Lifer eboos's Avatar
    I have it in my bike. It came in a used tank that I bought, and I've had it for over 2 years. No break down.
    Lifer obsolete's Avatar
    Norf Sho
    Brother-in-law hand it in his race car for... ummm... a long as time (years). No problem there.
    -Alex
    I believe Alex uses it in his tard... he's gone without a gas cap before and no spillage. : )
    derek, isnt that the same stuff that's in my air box next to the filter?
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    I have it in the TZ. It also keeps the fuel pump primed. Under hard braking the gas moves to the front of the tank and to the rear under accelleration. When the fuel pump is allowed to run "wild" it leads to premature failure......My ex always ran around with about a gallon of gas in her car and would need a pump every year it seemed. I would tell her never to let it get under a 1/4 but she would say "Give me some money" I would tell her "lets make a deal"
    Meriden, Ct
    I've got it in my Sv and it makes a ton of difference. Especially in places where you must rapidly throw the bike from one direction to another. I thought it was kind of hokey at first. But man is it nice not to have to deal with 20+ lbs of fuel sloshing around in the tank.
    Lifer Pittenger5's Avatar
    Austin
    Why do you fill the tank up?
    Zip Tie Alley #505
    I had it in a Hawk It Broke Down and turn to Maple Syrup Gino was cursing
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    track days
    Quote Originally Posted by BLACK SQUIRREL View Post
    There must be different brands out there. Mine was from HRC. It comes with a 125 when you buy it. Indestructible.
    Meriden, Ct
    because you can't see the fuel level with all that foam in the tank...
    Drain the fuel between races. Measure. Put in what you need plus 3 laps.
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    Quote Originally Posted by 07BladeRider View Post
    good subject, i have been thinking about throwing this in the bike this upcoming season
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    Austin
    Or put in how much you need for the race and forget the foam?
    Zip Tie Alley #505
    Foam is good, unless you LIKE to ride a donkey in the corners...
    Austin
    Shut up novice
    Pretty sure foam isnt gonna help me there
    Zip Tie Alley #505
    Suit yourself.
    Meriden, Ct
    Tell me what you mean by that statement. (bear in mind I already have the foam in my tank)
    Oct 2005
    Wrentham MA
    Gas weighs about 6.2lbs* /gallon.
    I developed and manage the fuel test program at LRRS** FYI - I see just 1 or 2 bikes that have this stuff in their tank...
    Interesting point: Most experts and top amateurs have very little fuel left in the tank when they get called into tech post race, for fuel testing...hint - stuffed tank or not, why carry extra weight.
    If you use pump gas - then you have approx 10% ethanol. Three weeks is about how long fuel lasts with methanol.....and that's with tight control on water absorption....(so get your fuel from busy gas pumps).
    Now you are going to say, "I keep fuel in the tank and use it next year.....or my car can sit for weeks"...... as water is heavier - what can't be absorbed sits in the bottom of your tank... and sure - your motor will start even after phase separation (but Octane rating is way down) but ever wonder why sometimes it feels like it might be down on power?.....
    Methanol has about 2/3 less energy per volume then gasoline. it is hygroscopic, meaning it will quickly absorb water vapor directly from the atmosphere resulting in Phase seperation of fuel and fuel efficieny can decrease between 2-40%.
    It is also good idea to install a water seperator filter(10microns or better).
    * weight depends on blend and additives such as methanol and how much H2O the methanol has absorbed-which is a big issue for performance***)
    **http://www.lrrsracing.com/spec_fuel_...EL_PROGRAM.pdf
    ***http://www.lrrsracing.com/spec_fuel_..._race_fuel.pdf
    All Goes for track days too
    Graham
    According to the dude at Riders Direct, it's $55, shipped. Seems to be pretty pricey pieces of foam.
  1. For Sale - Motorcycles | Track/race package! 2015 5x8 trailer, 02 SV650 race/track bike $5500
    By South of Heaven in forum For Sale
    Last Post: 07-30-16, 08:45 AM
  2. Replies: 9
    Last Post: 04-06-16, 11:04 AM
  3. Replies: 2
    Last Post: 10-17-13, 07:04 PM
  4. My 04 R6 race bike for your race/track sv650
    By eforer in forum For Sale
    Last Post: 05-23-12, 09:55 PM
  5. 2002 Honda F4i Race Bike with Stuff
    Last Post: 05-15-07, 07:15 AM
