Results 1 to 12 of 12
power commander woes..
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Question power commander woes..
    Ok so installed this here power commander thingy....loaded that map then went for a ride. I went to work and back...no problem..then went out for a ride a couple of days later and the bike crapped out about 2 miles from my house and would not start again. I disconnected it and it was fine. This weekend I gave it another whirl..hooked it up and loaded the map. Took it for a ride last night..idled good..warmed up and I went to the gas station. Everything seemed fine until I got about 1 1/2 from the station and it crapped out again...awesome. well i moved the ground from the frame to the battery and this seemed to clear the issue up. Could this have been the problem or do i have a bad power commander? bad map? I rode around for about 30mins after that without issue...
    Dec 2003
    Ma
    A bad power/ground connection was most likely the problem. I had the same deal last year at the gap and it turned out to be a lose ground wire.
    Manvile, RI
    cool..i hope so. The ground was not loose but i did not scrape the paint off of the frame....and it worked for a little bit then crapped out... seems to me if the gorund was bad it wouldnt have run right from the begining...that's why i am still concerned
    Haverhill, MA
    Your ground may have been good enough when you first connected it but it does not take long for corrosion to build up and make the ground no longer good enough. It could have even been that the ground loosend up just a little bit but that little bit was the part that was making it a good ground before.
    Grounding to the battery a good thing
    Joel
    Re: power commander woes..
    They are known for grounding issues. Connecting to the battery should fix it right up.
    derek
    Oct 2001
    Bedford, MA
    Is there any reason not to ground to the battery? I know I grounded my PC3 to the battery and I"m 90% sure all my other stuff is also grounded to the battery, any reason NOT to do this other then having a mess of stuff connected?
    Manvile, RI
    Joel
    hasnt been on there long enough for anything to build up...less then a month
    degs - ok cool...thanks!
    ben - ya just the mess I am trying to avoid...
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    is your battery good
    thats how i think i lost my map ?
    it started ok but the voltage was low
    bike batterys sux
    www.bostonmoto.com
    Forum Rules
    Manvile, RI
    i think so...it is less then 2 years old...seems to be ok now :notsure:
    May 2002
    Meriden CT
    i would check it with a meter
    just 2 make sure
    like i said mine would start right up
    but i checked it on the volt meter & it was only 11 volts .
    not good for high reving
    i take care of my batterys i never let it get cold & allways on the tender
    www.bostonmoto.com
    Forum Rules
    Manvile, RI
    Mar 2004
    woonsocket ri
    Re: i would check it with a meter
    Originally posted by beet
    just 2 make sure
    Last week you couldn't work your power commander and suddenly this week you're an Expert
  1. Need to borrow 9V Power Plug for Power Commander III
    By MikeyZ in forum General Bike Related
    Last Post: 07-17-14, 01:08 AM
  2. 92 WR250 Power Valve Woes
    By Kurlon in forum Dirty Bastards
    Last Post: 07-11-12, 12:57 PM
  3. Power Commander Q
    By jeantarrou in forum Bike Maintenance
    Last Post: 07-15-11, 08:16 AM
  4. WTB: Power Commander 02-03 R1
    By KillerMike in forum Wanted
    Last Post: 03-29-10, 11:02 AM
  5. power commander...
    Last Post: 05-12-06, 10:51 AM
