I saw this over there....
The pinch bolt should be wired to the far side to put the wire in tension if the bolt tries to loosen. I prefer cross drilled with the wire wrapped around the head.
The wire through the axle is only a single plane shear. It should be set to keep the axle tight be tension on both strands of the wire.
You are right at first glance it looks good. Very similar to the way I do mine. But with subtle differences that make it not so correct.
LRRS/CCS Expert #820 / RSP Racing / Woodcraft / MTAG Pirelli / Dyno Solutions / Tony's Track Days / Sport Bike Track Gear / GMD Computrack /
Wirelessly posted
You qualify to be a tech inspector at LRRS with those picky comments guys.
Will it stop the pinch bolt coming out? Yes. End of story.
It's not perfect but does the job. The pinch bolt could only turn about 1/4 turn. Not enough to let the axle slide out (IF the safety wire sheared at the axle).
My main gripe is the 1/2" of tail sticking out ready to tear skin.
I have seen far worse.
Wirelessly posted
I'm with stupid on this also. The thick wire kinda sucks.Originally Posted by csmutty
While it would do the job .... , I would never let that fly on my bike !!!!
I understand why that wire job looks so sh*ty ... Look how dingy / dirty the fork and wheel looks !!!!
Fair enough. I guess if the pinch bolt is wired at all it could never let the axle back out enough to shear the wire. Is the axle usually wired just as an anchor for the pinch bolt, or is it required?
Snowing even, and I've had to eat bright pink strawberry birthday cake 2 days in a row.
so would you just line the hole up and not care about torquing the axle or would you torque the axle and drill another hole when it stops lining up?
Tim
LRRS #44
Superbike Services 44
Torque the axle to spec, THEN drill.
When the holes line up, you know you're torqued.
I know what some of you might be thinking... And yes, over time as the threads wear and the metal fatigues lining up the holes won't bring you quite up to the specified torque... but the biggest reasons for torque specs is so that you don't unnecessarily OVER torque it and so that it doesn't come loose.... well, either are going to happen once you start using the holes for guidance and safety wire for security.
I didn't like the hole drilled thru the fork
Lazy is what I see! Drilling the fork at a critical strength point is not the smartest idea.
Back the axle bolt out a bit and drill the corner of it on an angle...probably bust a couple/few bits but it's the safest and rite way to do it.
Other than that, the wire job still looks like shit. It's lose and not pulling on the pinch bolt in a way to keep it tight
Would ya really call that a critical strength point?
I'd say it's more of a flex point since that's just where the axle gets pinched. Not really load bearing, is it?
I dunno, I'm no engineer.
You guys are way overthinking this haha.
Ask an engineer if a "flex" point should be altered in any way.
That was my point, it's in the thinnest part of the fork, and at a point where there is movement at times. Drill a hole in it, you take away material, you take away strength. Over thinking it, probably so..I wouldn't do that to my bike!
Can someone post a pic of a correct way to do it? I don't need any help doing it wrong....
This was how I was shown to do it.
Where are the ends twisted in that one?
As an engineer I'll throw in my interwebz expert opinion. Yes, it's a flex point. As such, drilling a hole in it creates a stress concentration at the hole. Where previously the stress of bending would be (ideally) spread across the whole area it will now focus more on the edges of the hole because that's where the material is not uniform. Over time this MIGHT result in a crack forming. A crack might form in that area anyway but having a hole there makes a crack more likely and guarantees that any crack that does form will do so starting at the hole. Given how little the metal actually flexes there (talking displacement not repetitions) I personally wouldn't be terribly concerned with it. That said, it looks ugly and hackish to me and even on a race bike I'd be inclined to do a better job.
Smelly Dog Racing - Website - Facebook,
LRRS AM #604 | DP Brakes | Race Tech | Spears Racing | All Balls Racing | Woodcraft | Armour Bodies | Spectro Performance Oils | Zero Gravity | Kabuto Helmets | Shorai
Right on top of the pinch bolt.
