Im sure a number of you are well aware I purchased a new R6. We are going to transform it into a track bike and I thought I would be interesting to everyone to see the process I got through to get it ready. The current plan is to break the bike down to engine and frame and then build it from there. The goal is to have it finished by mid to late April. Ill be using the bike for trackdays but Im pretty sure PK wants to race it once or twice so we will fully prep it. Ill keep this thread updated with photos and maybe some video as I have them. This is inspired by the Ducati build. Not many of us have millions to toss into a bike. This will be the average mans build.
The start...
2007 Yamaha R6
Just out of the show room and completely stock.
Next I made of list of parts Ill need.
Shock (penske or ohlins depending on budget)
Fork Revalve
Woodcraft Case Covers
Rear Sets
Exhaust
Rapid Bike fuel module by Dimsport
Bodywork
Clipons
Braided Brake Lines
Frame Sliders
Steering Damper
520 Sprockets front and rear
520 Chain
Spools
Stomp Grip
This weekend Im going to try and get the initial measurement on the bike with the computrack machine before anything gets done to it.
Thats it for now Ill update when the next step is complete.
This will be awesome. Thanks for doing the progression thing. Cool project.
dont forget to get something for the tank...so it dont go BOOM!
What about electronically variable velocity stacks
to increase mid range power ?
Shoulda got an 08 !
Just messing with ya dude...
I'd guess there's not that much to do other than
race plastics, sliders, case covers, safety wiring
and reversing the shifter...
oh and little of Pete's bouncing the thing up and down.
2008 Honda CBR 600RR
What's the advantage of going with the Dimsport fuel module vs a PC3?
James,
Congrats on the bike! Looks great.
I might be interested in snagging a couple of parts when you start stripping it down...
Can't wait to see how it turns out.
Anyone know for sure if the 08 tank can mount up to the 06-07's??? That would be a good conversion to do if the black is the same paint code. I could sell my mint 06 tank on egay and have no net loss... Better than blowing 120 bucks on those ripoff plastic chunks traxxion is selling.
Zip-Tie Alley Racing
LRRS/CCS #103
The dimsport can be transfered from bike to bike with just a wiring harness that can be purchased separately for each bike. It also hold two maps that you can change with a toggle switch.
As for the stock stuff. Im probably going to end up keeping it for now. We will have to see what happens with the build.
Dimsport - Tuning - Centraline - Odb - Rimappature - Engine - Performance
Call Kates he can get them. Im not sure who he goes through.
my buddy taylor hoffman bought that bike off of jeff....he got into racing this past season, ended up a top 5 amateur, i'm scared hes gunna be killin me next season haha.
note: hes the one that got me into riding when i was living in lake placid....i HAVE to stay ahead of him for bragging rights haha
Today I broke the bike down a bit and measured it up with computrack. For those of you not familiar with computrack, in a nutshell it measures the bike using specific targets on the bike and determines if there are any bends or twists. It also calculates any adjustments that will be needed to get the geometry to where we like it.
As you can see I took off the stock fairings and a bunch of the other stuff that I wont be needing.
Click for the slide show.
The measurement results came back and the bike was straight. Its a good start. I have the woodcraft parts on order and they should arrive by next week.
Sorry for the lack of updates but some work has been done. Not many pictures this time around. The camera batteries were dying when I was doing the work but I have some.
I put the bike up on the lift and laid out the parts I had to install. I have braided brake lines, woodcraft clipons, woodcraft case covers, woodcraft rearsets, and woodcraft frame sliders.
I started with the case covers. I removed the old covers.
I transfered the stuff from the inside of the left cover the new cover. Make a note or remember well where everything was situated or the new cover wont go on right. Also remember which order the bolts go in. On the right side a few of the bolts are a little longer then some.
Case covers installed.
Next I did the rearsets. Almost a direct bolt on. Directions were pretty good and made the job pretty easy. I chose to go with the GP shift. No brake light switch provisions on the woodcraft stuff so if you want to keep the bike streetable then youll need a pressure banjo on the master cylinder.
Frame sliders were next. Once again pretty easy. Remove the engine mount bolts and replace with the mounts for the sliders. After that install the pucks and youre good to go.
Next it was time to tackle the front end. Forks got revalved, new springs, and the brake lines. Having Kates around for this is key.
Forks off the bike
Getting cleaned
Going back together
Done with new valving and springs
Forks back on and braided lines installed.
As all this was going on a little safety wiring got done as well. Once again Kates was key. Bolts drilled and wire installed.
Im sorry but I dont have any photos of the clipons going on.
That is it for now.
hey, the pictures look nice. i think you've got a longer list of parts to install prior to riding season that i do.
i like the woodcraft, but why did you use that instead of the new OEM one? do they give a better clearance on the track? I'm asking because my cover cracked, and I looked at the woodcraft one when I was buying a new one.
Case covers? The bike is going to be raced at least once and you need some sort of case cover to satisfy the rules. In the case of a get off with case covers its less likely to grind through and drop oil on the track. Also the sliders on them are replaceable and much cheaper then an entire new cover.
I dont know what the prices for the OEM stuff is but in the event of a get off youre probably going to have to replace the cover again. I can probably just get away with replacing the slider on the woodcrafts for much cheaper. So yes the entire assembly might be more money but in the end it could be much cheaper. Besides you have to have them anyway to race the bike.
thanks for the input. i figured it was a clearence issue for racing. my OEM stator cover was $80 with an OEM gasket on eBay. if I end up replacing it again, I'll look into the woodcrafts.
and in the event you do repost to remove the nonsense: denno sucks.
