Results 1 to 14 of 14
Slicks
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Slicks
    Where are you racers getting them for the best price?
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Diamond Geezer Kip's Avatar
    Nov 2002
    Cranston ,RI
    Slicks
    My guess not to many are using slicks but if they are they are getting them at the track, but I'm not sure?
    I think Pirelli's are $370 or something like that.
    Slicks
    I was running a slick/DOT combo on my Motard and it was $1 less for the rear slick than the DOT I was using Dunlops at $280 a set at the track, mounted and balanced in less that 10 minutes
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Slicks
    $280 is a good price...probably more for a 180/120 combo. I was considering them for trackdays, but I'm going back and forth on just getting a race DOT...maybe even the new Dunlop Qualifier. I just haven't heard many user reviews.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    Slicks
    I run front + rear slicks on my fizzer4--bought them for like $150.for the set at NHIS!!!!
    (from R7)
    dunlops chatter like a half naked hooker on a cold winter night!
    Slicks
    That's not the case with Dunlop race tires, the 180 combo is the common size so they were $260 a set of the 208GP at the track last year, I was paying about $280 for a 150 combo because they are not a common size..or at least that's what Steve at the Dunlop garage told me
    Nov 2002
    Cranston ,RI
    Slicks
    Slicks are more then the 208 GP tires.
    Slicks
    not always, dunlop has been unloading the 16.5" slicks for $220 a set.
    The savings alone made a set of rims affordable.
    Adam
    http://www.webcrush.com
    AMA FX#60 SBK#160
    WERA #60
    Nov 2002
    Cranston ,RI
    Slicks
    What is the price of a set of 17" slicks. No one on this forum uses 16.5" tires.
    Slicks
    About $340.
    My point was the 16.5" are so cheap that buying a set of 16.5" rims makes sense sometimes.
    Adam
    AMA FX#60 SBK#160
    WERA #60
    Nov 2002
    Cranston ,RI
    Slicks
    Speaking of 16.5" rims at a track like Loudon did you notice a difference from them to the stock rims? I know they are lighter and all but at loudon is seems like most of the corners are stop and go corners where turning the bike from side to side isn't a real problem.
    Slicks
    without a doubt.
    any reduction in unsprung weight allows the suspension to work better--its not just about direction changes.
    you also gain better acceleration (minor) and better braking as well.
    and while lighter rims do all of the above, 16.5" are not about weight loss but greater contact patch and suspension setup.
    the tires external dimensions are the same as a 17" but since it has a slight smaller inside diameter, the sidewall is larger which is an extra bit of dampening to reduce chatter.
    a lot more sizes as well as compound AND carcass options as well.
    Adam
    AMA FX#60 SBK#160
    WERA #60
    Nov 2002
    Cranston ,RI
    Slicks
    Interesting. So a 16.5" tire is about the same diameter as a 17" tire?
    Slicks
    For Dunlop, yes.
    And not 'about', identical.
    We did a lot of measuring, especially last year when I ran 16.5"s in SBK, GP, and GT and the stock 17's in SS. The diameter's were exactly the same so there was no changes needed for geometry or gearing when swapping between the two.
    The 17" DOTs had the same numbers as well.
    Adam
    AMA FX#60 SBK#160
    WERA #60
  1. any 16.5 slicks around ?
    By turboraptor in forum General Bike Related
    Last Post: 04-23-12, 08:31 PM
  2. 16.5 Slicks
    By Rada in forum Pit Area
    Last Post: 10-31-11, 04:37 PM
  3. Pirelli Slicks 200??
    Last Post: 04-21-11, 07:48 PM
  4. WTB: Slicks
    By csmutty in forum Wanted
    Last Post: 09-12-10, 10:15 PM
