Results 26 to 50 of 64
Rookie Plan for Round 7
    Windham NH
    Re: Rookie Plan for Round 7
    Rookie Plan for Round 7-2014-09-13-15-00-a
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    I just wired the pinch bolt. I think by rights you should wire the axle too by getting a hole through there, but they don't say anything at tech.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Windham NH
    Do you know off the top of your head what you wired that pinch bolt to?
    Wire the bolt TO the axle! Plenty of meat to do an angle hole into the axle, and pinch bolt. Just arrange so when wired they're tightening each other.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    This is how I do it Drill a hole diagonally through the fork leg into the axle..
    Windham NH
    I did it as Kurlon suggested, thanks guys. Do I need to do the rear brake caliper mounting bolts? The way I'm reading the rulebook, yes, hoping you all know something I don't.
    Hiram, ME
    You do need to wire the rear caliper bolts.
    Windham NH
    Bike is all drilled for wire. I didn't break a bit until the last bolt, then apparently saved the best for last and broke 5 on the last bolt. Ended up going through the last 2 free adjacent sides with my last bit for the clutch win! Screwed it in, torqued it down, and got lucky with the functional holes in the right spot. On to bodywork.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Just because it hasn't been mentioned. Have a fuel can. Run whatever you want for Penguin, but for racing proper you need to run fuel bought on property.
    I can't imagine this being an actual issue for novices, but I tend to follow rules. Some people just ride over to the pumps and fill up. Others say that makes the bike unnecessarily top heavy. Personally, when I crash I don't want to have 5 gallons of fuel all over the track.
    I picked up one of those VP jugs from Miles. Somehow they have gotten away with keeping a vent and not having an overly complicated fuel release system that requires 7 hands to operate (like all of my other fuel cans).
    Windham NH
    I actually was curious how people manage gas with race/TD bikes. Is there some other way than draining the tank after TDs?
    Sep 2010
    Granville, NY
    You can run it out during practice and fuel up with track fuel before the race or drain your tank and put it in your truck/car/lawnmower.
    Senior Member WinVT's Avatar
    Winooski VT
    Or you can just run whatever you want and hope you don't get tested.
    LRRS #313
    Under what circumstances would a noob just trying to live through the weekend even be "tested"?
    Pete. Buy a siphon. Then let me borrow it.
    They do the checks randomly, so far I haven't had my name come up but I' due.
    For gas cans, I have a VP jug and it's great, I'm liking my 2.5 gal Tractor Supply jobber better. It's got a freaking thumb trigger. Invert can over tank, make sure nozzle is in the hole, push button. Release button when you've reached your desired fuel level. No mess, no vents, easy cheesy.
    http://www.tractorsupply.com/en/stor...t?cm_vc=-10005
    Sep 2010
    Granville, NY
    http://www.amazon.com/Hopkins-FloToo...y_indust_img_z
    http://www.amazon.com/World-Marketin...ds=siphon+pump
    Both of these work good. The second one can be found at almost any hardware store.
    The first one is more durable and has a longer hose so it is more convenient.
    FWIW. I've been tested 3 or 4 times.
    Fuel is not a concern as of now. You won't be getting tested as a novice. It is worth getting one of the 6 gallon "race" cans, just the lack of safety devices is nice. No real reason to run anything but Loudon gas unless you're elsewhere and run out. It's basically the same price as outside the track and has less ethanol.
    Windham NH
    I have one of the big VP jugs, I guess I can just try to grab gas each time I'm at NHMS next year. I'll probably buy one of those siphons too. Thanks Adam
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    That looks great but it doesn't say "Race Fuel" though. What would the am/ex's say??
    I'll be following Pete's lead next spring.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Mar 2012
    Chichester, NH
    Colin - I have one of these http://www.autozone.com/autozone/acc...uestid=1488443 that you are welcome to use. It's not great, but it works.
    I *think* the least expensive fuel at the track is the 93 Sunoco pump fuel. Round 6 it was like $3.999 a gallon. It's not ridiculously higher than 93 outside the track. Since I only need 87, yes, I'm leaving some money on the table by using the 93 for "non racing". Is it worth pumping out the 87 to replace with 93? Your call.
    Mar 2012
    Chichester, NH
    LOL. My 18 YO son, the other day asked if it was OK to use the fuel in that new fuel can in the lawnmower. I asked him what the new fuel can said on it. He said VP Racing Fuel. I then asked if we had a racing lawn mower... Then said it was fine (In his defense I do keep some premixed around for the chain saw that I've told him specifically not to use).
    You have an 18 YO that asked permission to do something?
  22. #47
    Mar 2012
    Chichester, NH
    He's actually a great kid. I'm not sure how the hell that happened.
  23. #48
    Hiram, ME
    At $3.99/gallon, it's worth trucking extra home for those of us that live in CT.
    Show up ready to pay your way with cash money? Or Visa/Mastercard accepted..
    Nevermind.. RTFM!
    8.3 Payment
    8.3.1 A rider may pay by cash, personal check, or
    credit card. MasterCard, VISA, Discover and
    American Express are all accepted.
  1. Rookie Weekend #246 Round 2
    By Tas in forum Race Reports
    Last Post: 05-20-15, 10:49 AM
  2. Rookie weekend -NV #629 Round 7
    By Femmekat in forum Race Reports
    Last Post: 09-10-10, 05:27 PM
  3. New Plan.....Maybe
    By lrrs428 in forum General Bike Related
    Last Post: 05-01-09, 10:06 PM
  4. your plan for 6/16,17
    By Kham in forum Rides & Events
    Last Post: 06-11-07, 01:12 PM
  5. So what's the plan?
    By R7 in forum Pit Area
    Last Post: 06-18-06, 09:38 AM
