Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
safety wire?
    Everybody to the limit!
    Winchester, MA
    safety wire?
    I drilled my drain plug for safety wire today. I used, get this...a hand drill. I'm not talking about a cordless drill, I mean one of those wood-and-gear mechanisms you saw in your grandfather's basement. It worked wonderfully. Very strange.
    safety wire?
    It's not strange at all!! Most people don't realize that a very low speed allows the drill bit to actually drill the metal rather than spin on it
    Winchester, MA
    safety wire?
    Here's a question, is there a problem with wiring the drain plug / oil filter to the exhaust header? It runs right there next to both of them and would make an easy place to do a loop over. It just seems like one of those things that *should* be a bad idea, but I can't think of a good reason why it is.
    safety wire?
    The header itself or a header bolt? I personally don't think it would be a good idea to tie it to the header
    I just changed the oil in my R1 and did the prep work at the same time. The oil filter i wired to a nearby radiator hose clamp just like the one i put around the filter and the oil drain bolt i wired to the collar on the crankcase that surrounds the drain bolt (drilled a small hole in it). The oil fill cap (put the one off my R7 on it because i didn't want to drill the R1 one) i wired down to one of the clutch bracket bolts. I'd go take some pictures but i'm kinda tired and lazy Maybe tomorrow
    Littering and........
    Jul 2004
    Vermont
    safety wire?
    Is there any reason why you cant wire the drain plug and oil filter to each other?
    safety wire?
    Depends how close it is and if anything is in the way
    Keep in mind when you wire (probably getting a little annal with this but.. ), the reason for the wire is to prevent the bolt from even coming lose, not to prevent it from falling out. Even the oil filter posted in the picture above is not pulling in a way to stop that filter from losening a small amount. That being said, if you can attatch your drain plug to your filter at points where the wire will "pull" the filter tight and "pull" the drain bolt tight all at the same time and have no slack in it, it would be fine
    safety wire?
    The way I did that filter is not ideal because I was too lazy to drill the bolt on the clamp, so it "could" loosen allowing the filter to loosen. Drill the bolt.
    safety wire?
    Originally posted by hessogood
    Pete hit me up if you need a hand with the wiring. I've gotten pretty damn good at it.
    thanks man, i think i'm just gonna do all the bike prep once i get down to VA.... i'm not gonna have any time to do it this week w/ work
    As for the low speed drill thing, i agree... at first i used a plug-in high-speed drill, but that was too fast, heavy & unstable at low speeds... so i switched to my electric drill that's smoother & slower... just barely squeezed the trigger. worked like cake w/ those bits i got
    GRONSEL'D!!! gixxer6's Avatar
    Jan 2003
    Pissed that I can't race...
    wow
    Originally posted by Paul_E_D
    Buy about fifteen 1/16th drill bits and Go here...
    http://www.slideruleracing.com/Workshop/srprep.htm
    Hey Paul..you drinkin when you do this? Cuz 15 bits is quite a large number! haahaaaaa!!! Just fokin wit ya bro!
    For real though..if you know someone with a drill press..USE IT!!!
    Gordon helped me with mine, and it was 10000000000 times easier than when I did it without a drill press!
    Heath Smith
    LRRS/CCS #337
    Low Down Racing
    www.racetireservice.com
    www.motorbikesplus.com
    Power by Dr. Hillsgrove
    Traction by Franimal Racing Syndicate
    05' KTM 525SMR,
    01' YZ426F
    05' Reiju RS1
    Says Vale to Colin at the end of the 2002 8 Hours of Suzuka: "Ok Colin, you better go out there and win. Because it is the ONLY way we will NEVER have to come here again!"
  1. Safety Wire...
    By Sheppo in forum Bike Maintenance
    Last Post: 06-11-11, 08:05 AM
  2. Safety Wire Your Safety Wire
    By Jim in forum Bike Maintenance
    Last Post: 12-02-09, 03:21 PM
  3. Safety Wire Pliers?
    By oVTo in forum Bike Maintenance
    Last Post: 05-22-09, 07:34 AM
  4. Safety wire ??
    By Half Squid in forum Pit Area
    Last Post: 04-05-07, 11:50 PM
  5. safety wire
    By barfpuke in forum General Track Day Talk
    Last Post: 03-20-06, 03:14 PM
