Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Spacer Machining
    Re: Spacer Machining
    I want a custom wrench for tightening the throttle cable adjuster on my WR's carb... what a PITA...
    Quote Originally Posted by Larry View Post
    What do you need and how fast? I have finally started moving equipment to my home shop and have my CNC mill up and running. Just waiting for a variable frequency drive for the lathe and I'll be ready to rock. If its really simple I can knock it out at work during lunch.
    Larry, I'll get exact dimensions this evening. But basically just a steel or aluminum rod, hollow, not threaded, about 1.25" long. I think the OD needs to be big enough to get a 5/8"-16 bolt in there.
    Large member Larry's Avatar
    Nov 2010
    Limington maine
    NUMBAH 9! your spacer is done and in the mail! Bring on some more work gents! I have a habit to support here!
    Thanks Larry! Serious question, do you have a mill also?
    Nov 2010
    Limington maine
    Yep. 3 axis CNC. I also have 3d modeling capabilities with SolidWorks and SolidEdge.
    Nov 2010
    Limington maine
    You know where I live. Or look me up at the track. I'm sure we can machine something up for you.
    Larry, do you have a waterjet or CNC plasma or laser cutter?
    Nov 2010
    Limington maine
    Negative on the sheet metal stuff. What are you looking to do? I'm sure I can get you to the right shop to fabricate stuff.
    I'm looking to make a fender eliminator for the VFR. If anyone has a local line on a laser cutter or water jet cutter, please let me know!
  1. CNC machining - aluminum proto fab (small quantity)
    By trider143 in forum Bike Maintenance
    Last Post: 09-25-10, 05:13 PM
  2. Missing a spacer?
    By xplicit in forum General Bike Related
    Last Post: 04-14-09, 06:28 AM
  3. Breaker bars and random machining bits
    Last Post: 02-08-09, 08:41 PM
