Results 1 to 10 of 10
Supermoto Masters
    Lifer Pittenger5's Avatar
    Austin
    Supermoto Masters
    What are you guys running for a supermoto master? I still have the stock dirt bike master on it, and its just too squishy.
    I have the motomaster caliper/rotor if that makes any difference at all.
    0 Not allowed!
    Zip Tie Alley #505
    Re: Supermoto Masters
    Masters need to be matched to the caliper. My Beringer BRO master would be crap mated to a stock 2 piston caliper for example. I want to say the Motomaster was sized to be functional with a stock dirt master, what year/make/model is your bike again, or do you recall what size piston the stock master is on it? A Honda TRX master of the right year might be a cheap upgrade to a slightly larger master to firm things up for you?
    0 Not allowed!
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
    Austin
    05 RMZ450
    This is the one thats listed as fitting on the moto master site
    https://products.moto-master.com/disk/?d=213012
    0 Not allowed!
    Zip Tie Alley #505
    Ok, so going from a axial 11mm master to a radial 12mm should be a decent jump in lever firmness. Honda TRX450 front master should be an axial 12.7mm bore if you want to try a cheaper option, and is popular with a lot of the Sumo community, though I'm seeing some say it's too firm when paired with the MotoMaster caliper. Brembo made axial 12mm calipers that can be sourced for reasonable money as well, typically use was older Ducati / BMWs.
    0 Not allowed!
    WMC original sdog30's Avatar
    Burgy
    Pretty sure I have a magura with my motomaster
    1 Not allowed!
    12 Ducati Multi, 17 Husky FS450, 15 KX450F sumo, 15 Husky 250SXF tard, 14 KTM 250SXF
    LRRS/CCS #66
    Lifer lopycam's Avatar
    Aug 2003
    Cow Hampster
    I am pretty sure I have a magura with my motomaster as well.
    I remember when I was looking, the ATV quad front master was the way to go as it has a brake switch and it is designed to work with two calipers so it pushed more fluid. I already had the magura master so I just used it.
    0 Not allowed!
    Lifer union's Avatar
    Blackstone, MA
    I ran a Brembo 15RCS and I paired it with a Brembo P4 30/34 caliper. The best brakes I've had on any bike. Nice firm lever and a ton of control.
    0 Not allowed!
    James
    12 KTM SMR 450
    07 CRF 250R
    LRRS/CCS #79
    NEMM #79
    GMD Computrack
    Diamondback Designs
    Robs Dyno
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    I have a moto master caliper with a stock master on one bike and with a brembo 16x18 on the other. I think anything in the 14-16 range will work for it. They were strangely hard to find, I got mine on Kurvey girl.
    0 Not allowed!
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Seacoast NH
    I have a TRX450 master on my WR with the stock caliper and some nice braided lines. It works. It was worth the $50 I have into it. But then I'm not experienced with top-shelf hardware here.
    Mostly I installed the TRX master because it is wired for brake lights and I was plating the bike. I ran the stock master when I was racing the WR.
    0 Not allowed!
    Blackstone, MA
    Just to add a bit. My bike came with the Magura master and caliper which I still have. It lasted one day at the track for me. There was no issues braking but I didn't like how soft the lever felt. Just didn't fit with my braking style I guess.
    0 Not allowed!
    James
    12 KTM SMR 450
    07 CRF 250R
    LRRS/CCS #79
    NEMM #79
    GMD Computrack
    Diamondback Designs
    Robs Dyno
