Results 1 to 20 of 20
I need some tires!
    Lifer lopycam's Avatar
    Aug 2003
    Cow Hampster
    I need some tires!
    Hi Guys,
    I just bought another set of wheels for my tard and the rear is a 5.4" width. The front is the standard 3.5".
    Dunlop seems to make the tire that would fit the best on the rear. Where can I buy some Dunlops?
    "Fitment specs Rear 165: 165/55×17 KR108 Rear
    Recommended Rim range (5.25-5.50), Best Rim (5.50)
    Width (162mm/6.37"), Diameter (628mm/24.72")
    Available Compounds: 3166 Soft and 3483 Medium
    Pressures: Hot on the warmers 23psi, or cold 21psi"
    Any other tire vendors here that have some suggestions?
    This will be used for track days on a tard. I am also considering dot's with tread so I could run in the rain. Thoughts? Please educate me.
    Thanks,
    Nathan
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: I need some tires!
    DOT race tires won't help you much in the rain, they won't get up to operating temp. You'd be better off with street tires (designed to run at lower temps) or rain race tires for wet conditions.
    Lifer lrrs313's Avatar
    Asheville, NC
    +1 on true rains in the wet. Put a good set of soft compound rains on and go have fun on the tard. They last forever and on a motard you can go rediculously fast for wet conditions. In the dry run the 170 Dunlop motard slick.
    -Brian
    15 S-Works Venge
    Nathan, are you sure that rim+tire size will fit on your YZ?
    I have a 5" rim with a 160 tire on mine, and the rim is offset on the hub and I have about 1/16" clearance with the chain. The chain does hit the tire once in a while but not enough to chew it up. And that's with a non O-ring chain as well
    Asheville, NC
    FYI the 170 Dunlop motard slick actually has MORE chain clearance than the 165 slick (and a lot more than the 160 DOT tire I had on my KTM for a little while). I was wondering the same thing but the Dunlop guy at the track told me it would clear, so I tried it. Turns out they just call it a 170; it's actually a more triangular profile to give a bigger contact patch at big lean angles.
    -Brian
    15 S-Works Venge
    Quote Originally Posted by lrrs313 View Post
    Wouldn't the wider rim push the sidewall out a bit more?
    Asheville, NC
    Yes, but the rub point for my bike wasn't the sidewall so much as the edge of the "tread" surface; I wore the edge of my DOTs completely off without touching the sidewall. Slicks were the same thing, just not as much. I think with the wider rim it might stretch the tire so that you may not have contact. I would recommend adding a chain guide like the one Graves sells to the top of your swingarm.
    -Brian
    15 S-Works Venge
    Aug 2003
    Cow Hampster
    Thanks everybody. So I learned that i should get a good set of race rubber and a good set of rain rubber if I am going to run in the rain. Got it.
    Need dry rubber first. Where do I buy it from? It sounds like dunlop makes the size that i want.
    Thanks,
    Nathan
    #331 CBR929RE's Avatar
    Bridgewater, MA
    if you want Dunlop call up www.racetireservice.com
    Asheville, NC
    The Dunlop vendor at the track. Check lrrsracing.com, I think there's a link in there.
    EDIT: Too slow. ^What he said.
    -Brian
    15 S-Works Venge
    Oct 2005
    Wrentham MA
    likewise on both my KTM and Husky Motard.......Pirelli's are another option. I run Pirelli on the KTM (still have Dunlop on the Husky)
    Graham
    Aug 2003
    Cow Hampster
    Does pirelli ( or anybody else) make a tire that will fit on the 5.4 rear width that I have? Any I over thinking it? Should I just through a 160 on there and run it or should I try to get a 165 or 170?
    Thanks guys and sorry for all the questions.
    Nathan
    Bridgewater, MA
    Quote Originally Posted by xsiliconkid View Post
    likewise on both my KTM and Husky Motard.......170 is just an aspect ratio -tire height to width.
    170 is the width in mm but that number isn't accurate for whatever reason but its close. 55 is the aspect ratio.
    Oct 2005
    Wrentham MA
    oh yeah....
    tire aspect ratio
    Section Height / Section Width = Aspect Ratio
    Graham
    Aug 2003
    Cow Hampster
    So, who is the favorite tire vendor on this site? I would like to support the locals. I am looking for track day rubber for the motard if that makes a difference. Slicks are fine as my tard is not street legal.
    I am hoping to do one if not both tony's days if I can swing it.
    Thanks,
    Nathan
    Feb 2009
    Lost in constant migration
    If your intended use is TTD's, talk to MTAG. They should be able to set you up with some Pirelli shoes, and they'll be at the track to help with setup and everything else. They're all forum members and supporters.
    If you want Dunlop, I'd talk to Steve Dunlop (not his actual name, but what everyone I know calls him), who is the dunlop vendor at the track. Dude's pretty cool. Has always treated me right!
    If you want Bridgestone, talk to S&C. Again, site supporters, and they are our local trackside support/parts/b-stone tires people. Link is in post 9.
    If you want Contis, or plan to run mostly bomo days, talk to bomo. For some reason I think they may be switching what brand tires they sell this year?
    In your shoes, sounds like your best bet is contacting www.racetireservice.com if you want dunlops, or MTAG if you want them for running TTDs and don't have anything against pirelli.
    Lots of dudes going fast on all the options, really. I believe it's a personal preference myself.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    I am painting my rims. So I am mounting new skins. Front is a 120/600R17 soft. Rear is a 165/630R17 medium. These tires have 5 races. Bridgestones slicks. You can have them if they fit. I told someone else that they can have them but they never called. I had mounted the same size tires on my tard before. Pm me if interested.
    Jan 2010
    Farmington, CT
    Mike is actually running YDC (Ultra-Soft) Front and YCX (Soft) Rear B-Stone slicks. Unless it is really hot out, these tires will work good. B-Stone also makes YCY (Medium) slicks. Last summer I ran YCX (Soft) Front and YCY (Medium) Rear slick Bridgestones and they worked very well.
    Rumor has it that BostoMoto is still selling Continental tires, but you need to pre-order before an event. I've decided to use Continental Race Attack tires this year on my SV650 and TZ250 race bikes.
    Aug 2003
    Cow Hampster
    PMed!
    Thanks
    Nathan
    Your right. I just tell Miles give me what I need.
  1. For Sale - Other | Free vintage truck tires - 7.00x15 - Decent yard tires (not roadworthy, IMO)
    Last Post: 06-03-14, 11:29 AM
  2. 4 195-65-15 tires
    By zxme in forum For Sale
    Last Post: 07-23-12, 03:26 PM
  3. Buy Tires on the I'net?
    By mikem317 in forum General Bike Related
    Last Post: 08-30-05, 03:52 PM
  4. i need new tires...
    By mr phil in forum General Bike Related
    Last Post: 08-12-05, 09:24 AM
  5. tires tires tires free tires
    Last Post: 12-16-03, 10:10 PM
