I'm going to use a bungee to keep them in place. If they're full, their own weight would keep them down fine I'm sure, not so much empty though
Printable View
Dude, just weld the gas tank to the frame..
Nice work Artic. My van is next!
Stop by this weekend at the track and we'll have a look at it.
Got a little bit done today. Finished up the front with a few coats of paint.
Attachment 39917
Got the new decking down
Attachment 39918
Snagged a tool chest for the trailer and a set of dedicated motorcycle tools. I did the same for the Jeep. Nothing worse than spending an hour each side of your trip to try and get tools together and put away. Only half as expensive this time since my Honda only has metric fasteners.
Attachment 39919
Looks great. I put a rolling tool box in my trailer too, just for motorcycle tools. I don't know if you plan on sleeping in your trailer, I use mine as a camper up at the track. Now would be a great time to put some rigid foam insulation in your trailer. I haven't done this in mine yet, and it's tough to keep it comfortable in there.
I just roll mine on and off. I bought some Pitbull parts and fabricated a trailer restraint for the roller:
https://scontent-a-iad.xx.fbcdn.net/...4a&oe=546F6ECC
if you did another sheet for the gas and propane tank, would you not need to strap them down?
That's a nice setup, I'm not sure if I can make the TRS work with my shelving plans but now you have me thinking...
Potentially, but items like this in open space really need a bit of tension on them. I'm going to set it up really simple where I can bungee it very quickly and easily.
Working "inside" today. Picked up a sheet of vinyl floor covering as there wasn't any plain black and white tile for a checkered flag pattern. This is fine with me, went down quick as hell. Trimmed the floor shape:
Attachment 39929
Then glued it down:
Attachment 39930Attachment 39931
Not perfect, but it should be fairly durable.
Here ya go Jim, easy enough, right?
Attachment 39932
ok now show me how to weld :)
i was gonna get this.
http://www.harborfreight.com/welding...der-61849.html
cuz i guts no money..
i actually have to weld some exhaust on my riding mower.. I assume this welder is fine for it.
Can you mix a little safety wire into this build, just for me - pls?
How much is this thing going to be when I buy it back?
LOL
Looks great, D!
I did, I had weak signal when I tried to load the pictures, said fuck it, then forgot to revisit later. I'll keep it in mind to have a look soon.
I'll see what I can do, bud!
ALL of the money, of course!
Getting pretty close to finished here. Rebuilt the hubs and got new tires. I have paint drying on Etrack that I won't install until morning, still need to pick up some bolts for the Condor wheel chock. I'm nixing the shelving idea in the front, just not enough space with the gynormous tool chest. I'll pick up some kind of cargo net where I can stack stuff and keep it restrained in transit. I ended up needing to stagger the motorcycles. The TRS is situated as far left and rear as it could go, and the Condor is as far right and forward. There's room for the bikes but there was going to be interference with the handlebars so I went with the staggered configuration.
Attachment 39979
That's awesome!!
Yeah i went there to help...while he worked, i helped to keep the Grom warm lol
Pulled the trailer from my shop in Brockton to home in Quincy last night. Wanted to put a few miles on the new hubs and have a chance to retorque lugs before running ~100 miles up to Loudon. Before this thing vibrated so badly I felt it in my truck chassis. Both tires were trashed and one of the hubs was had bad bearings. Replaced everything and this thing is butter smooth. About an hour worth or wrapping up this morning then more pics!
Ok, pics. I have some more Etrack to put down and need to finalize where gear will go but it's pretty close. Rethinking electrical, either way it's a later on project. Here's the front
Attachment 39998
Left side wall, going to add another piece of Etrack midway up.
Attachment 39999
Rear
Attachment 40000
CBR and Grom ready to ride
Attachment 40001
I'll be at the track all weekend, trailer will be parked in front of 11N if anyone wants to come by and check it out.
that CBR doesnt look "ready to ride" :poke:
