Results 1 to 15 of 15
Transponder mounting location
    Lifer eboos's Avatar
    I read in the LRRS rule book that says the transponder should be mounted on the fork tube, while the CCS rule book says no more forward then the rear axle. Since LRRS falls under CCS, which is correct?
    Lifer Pittenger5's Avatar
    Austin
    Re: Transponder mounting location
    I believe in LRRS events LRRS rules take precident. I could be wrong however. Although everyone I know mounts it to the fork tube.
    Zip Tie Alley #505
    put it wherever you want. mine is on top of the triple tree next to the ignition. i think the fork is a bad spot in case of crash. although i thought the tail was equally as bad when i raced CCS. put it in the nose
    Member Pookie's Avatar
    Feb 2006
    Nashua, NH
    I have the bracket mounted to the fork LRRS. I would just make sure to put it somewhere up front cause when they check with the sensor on pre-grid they are waving across the front of your bike.
    CCS uses a completely different transponder and holder and it is mandatory to run it on(or in my case in) the tail. You won't pass tech if you dont.
    Every place is a bad place depending on the crash.
    yup, right on the fork for me.
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    Feb 2004
    AMB strongly recommends the fork tube mount, which is why Steve Baron had the wording inserted into the rulebook. CCS more or less requires the tail mount because they're too lazy to check them when they're mounted properly.
    The problem we have at Loudon is that transponders are mounted all over the bikes, and this messes up the accuracy of electronic scoring, and manual scoring remains extremely important. (And opens up the numbers legibilty can of worms) CCS works as long as everybody is doing it the same, ("As long as the error is constant.") but Steve says he gets a clearer signal with the fork mount. Mounting the transponder transversely on the triple tree will cause Steve to radio your number to me to check your mounting, that's how weak the signal gets.
    The AMA finally figured it out and moved the mounting spec to the fork. The two years I was in T&S for the Classic, when the tail mount was in effect, all the bikes showed up red (weak signal) on Ken Rogers' computer until he turned the warning off.
    Johnny B. (the other one)
    Super Moderator legalspeed's Avatar
    Somersworth, NH
    Quote Originally Posted by eboos View Post
    If you race CCS, put it on the tail, if you are racing LRRS, mount it on the fork tube on top under the plastics.
    Most imortantly, don't forget to return them before you leave the track.
    LRRS\CCS\WERA #486
    Foxboro, MA
    ok so the rule is to mount on the fork tube, i got it, easy enough - its funny how people will still have trouble with that or just do their own thing
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    ill keep mine where it is
    Lifer a13x's Avatar
    May 2005
    Escondido, CA
    I mount mine to the end of a 5' stick extending off the front of my motorcycle.
    Boston --> San Diego
    May 2007
    Southern NH
    I'm gonna use a 6' stick...
    Reminds me of the scene from Something About Mary when he picks up the Hitchhiker
    Hitchhiker: You heard of this thing, the 8-Minute Abs?
    Ted: Yeah, sure, 8-Minute Abs. Yeah, the excercise video.
    Hitchhiker: Yeah, this is going to blow that right out of the water. Listen to this: 7... Minute... Abs.
    Ted: Right. Yes. OK, all right. I see where you're going.
    Hitchhiker: Think about it. You walk into a video store, you see 8-Minute Abs sittin' there, there's 7-Minute Abs right beside it. Which one are you gonna pick, man?
    Ted: I would go for the 7.
    Hitchhiker: Bingo, man, bingo. 7-Minute Abs. And we guarantee just as good a workout as the 8-minute folk.
    Ted: You guarantee it? That's - how do you do that?
    Hitchhiker: If you're not happy with the first 7 minutes, we're gonna send you the extra minute free. You see? That's it. That's our motto. That's where we're comin' from. That's from "A" to "B".
    Ted: That's right. That's - that's good. That's good. Unless, of course, somebody comes up with 6-Minute Abs. Then you're in trouble, huh?
    [Hitchhiker convulses]
    Hitchhiker: No! No, no, not 6! I said 7. Nobody's comin' up with 6. Who works out in 6 minutes? You won't even get your heart goin, not even a mouse on a wheel.
    Ted: That - good point.
    Hitchhiker: 7's the key number here. Think about it. 7-Elevens. 7 doors. 7, man, that's the number. 7 chipmunks twirlin' on a branch, eatin' lots of sunflowers on my uncle's ranch. You know that old children's tale from the sea. It's like you're dreamin' about Gorgonzola cheese when it's clearly Brie time, baby. Step into my office.
    Ted: Why?
    Hitchhiker: 'Cause you're fuckin' fired!
    "A man who views the world the same at 50 as he did at 20 has wasted 30 years of his life.
    Muhammad Ali.
    Lifer brewmaster's Avatar
    Apr 2004
    Portsmouth, NH
    Dave if you are 1' behind Alex at the end of a race (on the leaders lap) I'd be impressed!
    M900ie
    SS750
    69 gas gusslin' Chevy
    LRRS EX #418
    May 2007
    Southern NH
    I'd be impressed if I were even in the same race! He's likely to be an expert before I ever become an amatuer!!!
    Muhammad Ali.
    KB KB's Avatar
    Manchester NH
    Mount it as far forward as you can.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    If I had mine on the rear in one of the races I would have ended up 2nd. I have mine on the front fork where I won by .009 seconds. Take any advantage you can give yourself. You may need it some day. + It is a little more protected. When they come up to check transponders I just point to where it is for them to get a signal so there is no guessing.
  1. Vacation Location/property
    By Manny in forum Off-Topic
    Last Post: 07-12-07, 08:14 PM
  2. FAWK!!! Forgot to turn in my transponder
    Last Post: 08-07-06, 08:33 PM
  3. Transponder clips?
    By R7 in forum Pit Area
    Last Post: 08-15-04, 09:22 PM
  4. Central location?
    By suppoz in forum Rides & Events
    Last Post: 04-28-03, 02:30 PM
