Results 1 to 7 of 7
transponders
    MEM mmarsden's Avatar
    Sep 2010
    chatham,nh
    transponders
    does anyone kno why lrrs uses the transponders that seem to be the most expensive. i looked on the ccs website and the company they use for transponders have them as low as $80 to $190..
    Re: transponders
    Quote Originally Posted by mmarsden View Post
    The lower priced units aren't suitable for anything faster than dirtbikes on dirt or gokarts.
    Sep 2010
    chatham,nh
    Re: transponders
    The westhold company sells them from a link form the ccs website and says up to 300mph.. http://www.westhold.com/products_timing.html - check it out
    Re: transponders
    That's for other tracks, NHMS uses the AMB system that isn't compatible with Westhold's units.
    Sep 2010
    chatham,nh
    Re: transponders
    ohh - got yah.. im always looking to save money- prob cost alot for track to switch rather than save me 150bucks..
    Posting Freak Scottg22's Avatar
    NH
    Re: transponders
    AMB is a leader in transponder/timing/scoring.
    The big goofy UGLY transponders CCS maybe cheape but they dont really do much. All it will provide you with is your best lap of a session (at least posted at the track).
    AMB is a much bigger company, their stuff works the best and like you mentioned, the track is setup for AMB.
    That and CCS makes you mount that big ugly box on your tail section.
    Member STREET&COMP's Avatar
    May 2010
    Troy, New York
    Re: transponders
    Quote Originally Posted by Scottg22 View Post
    And with that you get companies that make things like this http://www.blindapex.com/timers.html
    DESCRIPTION
    The DisplayIT is an in-car lap timer that receives timing and scoring information from a data transmitter that is connected to the AMB timing system.
    (AMB transponder required).
    The DisplayIT can also be used with an infrared receiver-transmitter pair that is also available from Blind Apex.
    SPECIFICATIONS
    Lap memory: Last 34 laps in non-volatile memory
    Radio: 900Mhz, frequency hopping
    Required voltage: 7 - 18V
    Power consumption (normal): 0.6W (50mA @ 12V) (Fuse should accept >=250mA)
    Power consumption (receiving data): 1W (85mA @ 12V)
    Polarity of DC connection: No polarity (diode rectified). Power cord included (bare wire end)
    Dimensions: 4.75” x 3.25” x 1” (LxWxH)
    Casing material: ABS-PC, waterproof design
  1. For Sale - Other | 2 AMB Transponders (New Style)
    By Ductard in forum For Sale
    Last Post: 04-04-17, 11:07 PM
  2. Transponders
    By wiggeywackyo in forum Pit Area
    Last Post: 08-10-15, 12:05 PM
  3. Transponders at LRRS
    By Schramm in forum Pit Area
    Last Post: 04-30-15, 11:23 AM
  4. PSA: Charge your Transponders
    By nt650hawk in forum Pit Area
    Last Post: 11-12-12, 10:55 PM
  5. Transponders
    By Jim in forum Pit Area
    Last Post: 01-03-12, 11:29 AM
