1
Charge 'em!!
LRRS 878 Clapped out Gixxah
Speaking of transponders. What's is the deal for first time racers? Rentals and the like, do we just zip tie em to the bike? or is there somewhere special we have to put them? Also how much do they cost to rent, because I don't wanna spend all that money right up front.
I believe first time racers get a free transponder rental for the first 3 weekends. You will need a mount to put it on your bike. Mounts can be bought at street and comp. Most put the mount on the fork tube between the upper and lower triple clamp. The Mount is fastened to the fork tube with 2 zip ties.
DONT FORGET TO CHARGE TRANSPONDERS!!!!!!!
CHARGE EM UP ERRRRBUDDY
Alright boys and girls dont forget to plug em in and charge em up!!
from the rule book
19.27 Transponders must be mounted according to the following:
19.27.1 Transponders must be mounted at the front
of the motorcycle as close to the axel verticalcenter-line as practical.
19.27.2 They must be mounted vertically, with the fixing
pin up, at a maximum of 120 cm or 4 feet from the race surface.
19.27.3 There must be no downward obstruction between the transponder and the racing surface.
This means no metal, carbon fiber between the transponder and the racing surface.
19.27.4 The maximum temperature should not exceed 50c or 122F.
19.27.5 Transponder holders must be affixed to the machine in a safe and workmanlike manner
using tye-wraps or pop rivets.
19.27.6 The fixing clip must be pushed through as far as possible.
Graham
though, can I get a reminder to UNPLUG the damn thing after this weekend? First session at the TTD in jersey almost sucked thanks to a flat battery. Once of these days I'm gonna get off my lazy ass and wire the thing off the ignition switch. Probably sometime around when I get off my lazy ass and replace the keyed ignition with a rocker switch.
Smelly Dog Racing - Website - Facebook,
LRRS AM #604 | DP Brakes | Race Tech | Spears Racing | All Balls Racing | Woodcraft | Armour Bodies | Spectro Performance Oils | Zero Gravity | Kabuto Helmets | Shorai
wired transponder really poses a problem tho if you ever wanna do an endurance race where you need to put your transponder on the bike when you get on it to go out for you session... just sayin
You had the AMB transponders fail on you or the new style CCS jobbies?
LRRS Am #331
I haven't charged mine since October. Thanks Jim
LRRS Am #331
What transponder?
CCS #31
I'm a little jealous of all you guys with transponders to charge...
