Results 26 to 50 of 63
New to USCRA
    Branford CT
    Re: New to USCRA
    Thanks Josh. I have a belly pan but the bike has a Hindle exhaust so it may not fit. This might be my only option
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: New to USCRA
    I still have one hanging on the wall. Complete with holes from the BFSP race on Dumpster Fire.
    Get some stiffer springs to keep it from dragging badly. You ain't no jockey mang
    Branford CT
    Re: New to USCRA
    I did ordered new fork springs. The belly pan I have may work but its kind of beat up. Not sure if i need to order a new one.
    Re: New to USCRA
    Patch it up, fiberglass isn't too hard to work with if you're going for function over looks.
    Re: New to USCRA
    If?!! It's an ex500...
    Branford CT
    Re: New to USCRA
    Your 500 lol
    Re: New to USCRA
    Your 500 lol
    My ex... Get it?
    Branford CT
    Re: New to USCRA
    Clever sir!
    What company makes bodywork for these bikes?
    Re: New to USCRA
    Clever sir!
    I believe it is airtech.
    Branford CT
    Re: New to USCRA
    thank you, just incase I need to order one. I might just do what josh did.
    #277
    Member lrrs398's Avatar
    Apr 2013
    Wayne NJ
    Re: New to USCRA
    There are three current LRRS racers (BJ Horsham, Joe Latona NESR screen name - smokinjoe, and John Lear) in garage 12A that race EX500's. They as well as Dana Temple (Penguin school) can provide great information about that bike. They might already have bodywork / belly pan that will fit.
    Branford CT
    Re: New to USCRA
    I will have to get in contact with them. A new pan is 172 bucks from that airtech place
    Branford CT
    Re: New to USCRA
    Can you run a lightweight battery in USCRA? I assume not
    Re: New to USCRA
    Branford CT
    Re: New to USCRA
    Ok that's what I thought
    Re: New to USCRA
    Yes you can.
    Branford CT
    Re: New to USCRA
    Oh really! Ok thats good to know. I need a new battery so I was thinking of getting a shorai
    Re: New to USCRA
    That just seems so wrong haha.
    Re: New to USCRA
    You don't NEED a battery, so lightweight vs none isn't really anything to get worked up about. Cost also isn't crazy, available to everyone, etc. The old trick with points bikes was to run them (no starter) off a 9v so it's not a 'modern' thing to run lightweight batts.
    Branford CT
    Re: New to USCRA
    That sounds complicated josh! But, its a very valid point!
    #277
  21. #46
    Re: New to USCRA
    bump start the fucker like 90% of the bikes there
  22. #47
    Branford CT
    Re: New to USCRA
    Its not a vintage cool ducati… its a EX500 guys lol
    If you want to get rid of that wall art let me know adam
    #277
  23. #48
    Branford CT
    Re: New to USCRA
    Would this be acceptablehttps://www.airtech-streamlining.com.../EX5003OCP.JPG for a pan??
    #277
  24. #49
    Re: New to USCRA
    Well... look at the rulebook and see if it meets the requirements?
    Quote Originally Posted by 2019 USCRA Rulebook
    21. Belly pans are required on all machines. The belly pan
    should be constructed of a suitable material (i.e steel, aluminum
    or fiberglass) and be of a sufficient size and depth to adequately cover the surface area of the bottom plane of the motor and
    have the ability to contain at least 3 quarts of oil (4-stroke), and
    1.5 quarts of oil (2-stroke). The belly pan must be affixed to the
    chassis at a minimum of three points and must contain an absorbent material created for the sole purpose of containing
    Feels like the last sentence is cut off but that's how the rule is written. If you can suitably attach that pan, and it'll hold the required volume while covering the bottom of the motor it'll work once you add an absorbent pad as required.
    Branford CT
    Re: New to USCRA
    Where did you find the rule book? is on faceybook?? if so I cant see it. But thank you, I think this looks like an easier option and cheaper than buying a new lower.
    #277
  1. USCRA Questions
    By knarlydog in forum Pit Area
    Last Post: 06-12-16, 10:37 AM
  2. #763 USCRA US Vintage GP
    By rolker in forum Race Reports
    Last Post: 05-23-13, 10:58 AM
  3. FZR 400 for P89 and USCRA
    By eforer in forum Pit Area
    Last Post: 09-26-12, 07:51 AM
  4. USCRA May 21/22 NHMS
    By nt650hawk in forum Pit Area
    Last Post: 06-01-11, 06:49 AM
  5. USCRA Racing
    By Doc in forum Pit Area
    Last Post: 03-23-11, 05:25 PM
