I've become very indecisive choosing some tires this year and I've now decided to buy some extra wheels for track use. I'm not racing but I figured this may be the right place to find an answer to a question about these tires. (assuming some of you guys use this tire) I'm going with the SC2 (soft) in the rear. I'm curious if I should go with the supersoft compound up front (SC1) or the SC2. I can run 27's around the track and will probably improve this year. I know that a street tire is fine for this pace but I got a hell of a deal on these tires at the moment. I'm probably 235-240 lb's all geared up in case weight is a deciding factor. This is my 1st time buying a tire that have a choice in compounds so I'd like to get the right combo from the start. What would you suggest? Thank you.
