Results 1 to 22 of 22
650r Chain/Sprocket Question
    Member timv2444's Avatar
    May 2010
    Shirley,MA
    Hey everybody,
    While riding it sounds like my chain is working pretty hard. I dunno if it's bad rear wheel alignment or too tight of a chain. I've only had the bike for one season and put on about 3k. The rear sprocket doesn't seem to be worn. I planned on replacing the chain and sprocket in the near future anyways Any help would be appreciated. Located in Shirley,MA
    Thanks again
    Banned G21forme's Avatar
    Lakes
    May 2010
    Shirley,MA
    Re: 650r Chain/Sprocket Question
    Forgot location -- Shirley,MA
    Describe working hard.
    Who put the current chain/sprocket on?
    May 2010
    Shirley,MA
    Sounds like a constant growl / clicking noise. I don't know who put on the current chain/sprocket. I'm still fairily new to the street so may be normal but I don't know. Thanks
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    How much play is in the chain? You should be able to move the chain up and down 1" total movement at least. It's more likely overtight than undertight. If it moves up and down more than 2" it's probably too loose. Those are just general guidelines. For some more specific information on your specific bike search google.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Lancaster
    Wirelessly posted
    If you wanna meet up I can take a look at it for you.
    Corey
    May 2010
    Shirley,MA
    Chain play is only about 1/2" up and 1/4" down.
    - Corey, I'll try to narrow down a day and I'll shoot u a pm and see if your avail. Thanks
    Fairhaven, Ma
    That sounds way too tight. It can put unnecessary stress on lots of things. Is it tight to the touch? It should seem loose.
    LRRS EX 151 AMSOIL
    May 2010
    Shirley,MA
    Yeah it does seem tight. I imagine when I'm riding it's tighter, correct?
    Fairhaven, Ma
    Yes it will tighten up as soon as you sit on it.
    http://www.youtube.com/watch?v=D_WdhZGJsTg
    LRRS EX 151 AMSOIL
    May 2010
    Shirley,MA
    Damn that's not good. So should I strt from scratch with a new setup that is adjusted properly? I bet the chin and sprockets are somewhat damaged.
    I93/495
    1-1.5" is what your slack should be.
    650r Chain/Sprocket Question-chainslack-jpg
    You can download all sorts of info from this site, including the factory service manual.
    http://homepages.slingshot.co.nz/~shanetp/Index.html
    Attached Thumbnails Attached Thumbnails 650r Chain/Sprocket Question-chainslack-jpg
    2012 Tiger 800 XC
    Fairhaven, Ma
    Before you ride it again give the chain some slack. I wouldn't go as far as replacing everything already. Loosen it up, ride it, and check the chain for loose rolllers and binding links.
    LRRS EX 151 AMSOIL
    May 2010
    Shirley,MA
    Thanks guys' I'll do some adjusting tomorrow and keep you posted.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Did you get it new from the dealership? I'd call them up and bitch.
    who knows
    I'm also right down the street from you in Bolton. If Corey's working I'll be around all day tomorrow if you want to swing by or I can take a ride over since I hear the sun may be out.
    Wirelessly posted
    Text me I need your help when u get a chance
    Lancaster
    you know my number lol
    Corey
    May 2010
    Shirley,MA
    Hey guys' finally got around to adjusting my chain slack. The bike seems to ride better, and the stress on the chain sounds like its reduced.
    --Corey and Scuba I my take one of you up on just checking it out and make sure everything is copacetic. Either of ou guys free next Sat / Sun for a few? Thanks nd let me know.
    Lancaster
    Wirelessly posted
    Quote Originally Posted by timv2444
    I'll be around until 1130 on Sunday
    Corey
    May 2010
    Shirley,MA
    Corey,
    Maybe next weekend. I got called into work for Sunday. Booooo. Thanks man
    Wirelessly posted
  1. Chain/Sprocket Install Technical Question
    By LXnastynotch93 in forum Bike Maintenance
    Last Post: 05-18-14, 12:03 PM
  2. TAKE OFF's FS - Plus a Chain/sprocket set for an R6
    By fastfreddy333 in forum For Sale
    Last Post: 09-11-12, 12:15 PM
  3. chain and sprocket
    By dingley00 in forum Bike Maintenance
    Last Post: 06-23-11, 10:21 PM
  4. another chain/sprocket
    By JonT in forum General Bike Related
    Last Post: 06-11-10, 08:06 AM
  5. Rear sprocket and chain question
    By Dannyboy in forum General Bike Related
    Last Post: 11-12-02, 10:17 PM
